wide open throttle
augidog
PostPosted: Thu Jan 01, 2004 10:53 am    Post subject: wide open throttle Reply with quote
With the correction of the hoses to my vacuum amplifier, I finally have full throttle acceleration when the second butterfly opens up.
Its slight, but now I can hear and feel it kick in.
Is there anything else that I can do to help this react even more?
It's getting there, but I know its not up to speed yet.
With my previous cars before the Porsche, carb cleaner usually helped this out.
Is the intake manifold worth taking apart and cleaning?
Would cleaning just the throttle valve housing be enough?
Roger
PostPosted: Fri Jan 02, 2004 4:07 am    Post subject: Reply with quote
Its not worth pulling the mainifold. Cleaning the throttlebody is a good idea but it is usually done to slove poor idleing problems. I doubt that varnish and build up will cause much restriction at WOT. I would also check your CIS preasures, and the injector delivery rate and spray pattern.
1981 924 NA
