-78 924 warm starting problem
possu
PostPosted: Mon Dec 29, 2003 10:27 am    Post subject: -78 924 warm starting problem Reply with quote
Hi. I have a problem to start when my car have been stand by a while it doesnt run.
I have solved a problem by putting a button(12volt) in cold start valve that i can open that manualy it s working but i want to fix that properly, any hints how i solve my problem?
BTW.Sorry my bad english"
Roger
PostPosted: Mon Dec 29, 2003 11:46 am    Post subject: Reply with quote
What year and model?
1981 924 NA
possu
PostPosted: Mon Dec 29, 2003 8:59 pm    Post subject: Reply with quote
-78 924 its in topic.
dpw928
PostPosted: Tue Dec 30, 2003 2:23 am    Post subject: Reply with quote
Possu,
The cold start valve is only supposed to work when the engine/water temp is less than approx 100 F. If it doesn't work at that temp, the thermotime switch is bad. If you have a problem at warmer temps the probable problem is in the warm up regulator or your air/fuel adjustment.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
PostPosted: Tue Dec 30, 2003 6:03 am    Post subject: Reply with quote
There is a constant 12 volts which runs to the thermo time switch on the back of the head, this then flows through the switch ove to the cold start valve, the +12 volts which runs to the thermo time switch is fed by the fuel pump relay/power system, check to see if you have power at the thermo time switc if yes then the thermo time switch is bad, if no then you have to trace the wires and find out where the power break is
3 928s,
CMXXXI
PostPosted: Tue Dec 30, 2003 7:44 am    Post subject: Reply with quote
Don't overlook the check-valve at the fuel pump and the accumulators. Between them, they are always warm start problem culprits.
'79 Eurospec 931
dpw928
PostPosted: Tue Dec 30, 2003 8:03 am    Post subject: Reply with quote
CMXXXI,
Knew I was forgetting something. Good catch. They say the memory is the second thing to go when you get old. Think I'm in trouble.
Dennis
81 931 5 sp
78 928 5 sp Silver
possu
PostPosted: Tue Dec 30, 2003 8:30 am    Post subject: Reply with quote
Thanks.
Can i broke something with my modification in cold start valve?
When i give 12 volts manualy to that.
Roger
PostPosted: Tue Dec 30, 2003 10:41 am    Post subject: Reply with quote
Sorry I missed the year and model in the subject. Porsche went to a single 40cc accumulator in 79 ir 80, and the check valve on fuel pump. That was the factory solution to the warm start problem. I belive that you have two 20cc accumulators. Your modification to the cold start valve has been done many times and you wont damage anything.
1981 924 NA
numbbers
PostPosted: Tue Dec 30, 2003 11:19 am    Post subject: Reply with quote
Possu, I don't think you could have broke anything. The thermo-time switch supplies ground to the cold start valve. Putting a constant 12V on the valve will not do anything once the thermo-time switch has opened. The hot start problem is caused by the thermo-time switch timing out too soon. Even under hot conditions the thermo-time switch supplies ground to the cold start valve for approximately three seconds. This give a shot of extra fuel to the mixture for starting. The problem is that three seconds of extra fuel is not always adequate for an old engine where everything is not up to snuff.
The hot start problem mod that I wrote for the tech section allows you to override the thermo-time switch to get your car started.
PostPosted: Tue Dec 30, 2003 11:30 am    Post subject: Reply with quote
This problem is caused when the car sits after being run and the heat in the engine compartment causes the fuel in the lines to boil. Its the classic vapor lock that has been a problem for decades in many cars. In our cars, Porsche has tried to reduce this problem by running a radiator fan after shutdown and by trying to keep pressure in the lines (causes the fuel to boil at an higher temp).
The solution is to run the fuel pump long enough to purge the lines of vapor.
