Kenodog
Posted: Sun Dec 28, 2003 1:27 pm Post subject: Gonna be good,(please) |
So I got the last piece in the mail today.A rebuilt WUR from SpecialTauto.Altogether here's the list of parts going into my 931.
Professionally re-built turbo with new exhaust wheel and housing.
Second oil cooler,stripped and alodined.
Four new exhaust valves.
New gaskets,ALL.
New valve springs,ALL.
New pressure plate.
New throw out bearing.
New Bilstein struts.
New Weltmeister 200# springs.
TotalSeal ring set.
New clutch.
Re-built wastegate with new boot.
New water pump.
New thermo time switch.
New oil pressure sender.
New valve guides,ALL.
New cold start valve.
Port and polish head.
Polished throttle body.
New leads and plugs.
New,two stage,switch on the fly boost controller.
VDO boost/vacuum gauge.
Ceramic coated exhaust manifold.
All new radiator hoses.
(soon) aluminum 944 radiator.
The head and block will be going in on Monday to be planed and o-ringed then assembled with all of the listed parts.
After I get it back i'll install it then plumb in the Spearco air-to-water intercooler.Then to Porsche for fine tuning,then to the dyno for the (hopefully)big numbers.Wish me luck.Pics will be posted as soon as possible.Thanks for all the help in procuring parts and matters with technical issuses.(I'm sure there will be more.)
And a Happy New Year. _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
CBass
Posted: Sun Dec 28, 2003 5:26 pm Post subject: |
Good luck, this should make for a very nice engine
You might want to do something about the rear suspension too however, stiffening the front end only will result in a car that tends to understeer more.
A set of 968 M030 sway bars would do the trick, the rear bar is adjustable, and at it's hardest setting, promotes a bit of oversteer in the 968, would make for a neutral balance in a 931. My 2 cents.  _________________ '81 931 in various states of assembly |
welder
Joined: 16 May 2003 Posts: 158 Location: cumberland,maine
Posted: Sun Dec 28, 2003 9:12 pm Post subject: |
You have ALL the goodies, sounds great. It's so much better to assemble all the new parts and then a one time big rebuild to the finish product. How long has it taken to get you to get all these parts together?? _________________ I have a 78 n\a currently under restoration. |
Posted: Mon Dec 29, 2003 1:00 am Post subject: |
I agree, get the M030 rear bar; cheap, high quality, adjustable, factory part, and just what you need! _________________ Vaughan Scott
Porschephile
Joined: 04 Nov 2002 Posts: 825 Location: Denver, Colorado
Posted: Mon Dec 29, 2003 8:25 am Post subject: |
| CBass wrote: |
A set of 968 M030 sway bars would do the trick, the rear bar is adjustable, and at it's hardest setting, promotes a bit of oversteer in the 968, would make for a neutral balance in a 931. My 2 cents.  |
does that go for the 924S too? I've got the 968 M030 rear sway...I think right now it's either on the softest or the medium setting. _________________ werd B. |
CBass
Posted: Mon Dec 29, 2003 8:48 am Post subject: |
I think that would hold true for the 924S as well, in having a nice neutral balance. The 968 MO30 had a relatively stiff rear end, with the addition of those little helper springs it had on the shock.
Back on topic however, are you using an '80 turbo still? _________________ '81 931 in various states of assembly |
Kenodog
Posted: Mon Dec 29, 2003 10:41 am Post subject: |
If you're asking me,no i'm not.The PO changed it to an 81.BTW what is a good price for this rear M030? And is it any better than the stock one i've got?(My car has the M471 handling package with oversize swaybars front and rear.)Also how hard is it to install in an 80 931?And will I NEED coil overs because I can't afford another big ticket purchase.All that crap listed above was about my limit and I still have to pay for the machine work to the head and block.($1K) _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
CBass
Posted: Mon Dec 29, 2003 11:15 am Post subject: |
Finding a used set is not that easy, there were only 16,000 968s made, and not too many of them had M471. Usually when one is parted out, the 951 guys jump on it.
http://www.smartcart.com/Paragon/cgi/display.cgi?item_num=944CUPSB
Paragon sells the 19mm 3 setting rear bar for $150, and the non adjustable 30mm front bar for $300. These are the same bars as used on the 944 Cup cars as well.  _________________ '81 931 in various states of assembly |
