RE: Changing the fuel filter
duncmac
PostPosted: Wed Dec 03, 2003 1:19 am    Post subject: RE: Changing the fuel filter Reply with quote
I'm going to be doing this at the weekend (along with the oil and sparks).
Do I need to get any rubber hose in case whats there is turning.
If so what type and size.
Thanks
jts924s
PostPosted: Wed Dec 03, 2003 5:16 am    Post subject: Reply with quote
Are we talking 924S? If so, the line from the fuel pump to the filter has pressed-on fittings and probably needs to be sourced from Porsche. The line out of the filter is probably either 12 or 13mm (outside diameter) and needs to be of a high-pressure type. NAPA should have it, but if you have to go to the dealer anyway...
I'm sure you know, but make sure you de-pressurize the system first. Even then be prepared for some spillage.
'87 924S, now in better hands. Have a look.
