jts924s
Joined: 16 Aug 2003 Posts: 52 Location: Littleton, CO
Posted: Wed Dec 03, 2003 5:16 am Post subject: |
Are we talking 924S? If so, the line from the fuel pump to the filter has pressed-on fittings and probably needs to be sourced from Porsche. The line out of the filter is probably either 12 or 13mm (outside diameter) and needs to be of a high-pressure type. NAPA should have it, but if you have to go to the dealer anyway...
I'm sure you know, but make sure you de-pressurize the system first. Even then be prepared for some spillage. _________________ '87 924S, now in better hands. Have a look. |
