QuadESL63
Posted: Sat Nov 29, 2003 2:59 pm Post subject: Q: 924 Turbo undersize main bearing set |
Anyone know where I can get a set of 0.50 under main bearing set?
BTW, can I use the one from other Porsches?
Thanks! |
1982Porsche924
Joined: 14 Nov 2002 Posts: 679 Location: Cupertino, CA
Posted: Sun Nov 30, 2003 4:17 am Post subject: |
www.performanceproducts.com - $79.95
Part number 904271.
The main bearings are the same as the N/A 924. _________________ 1979 Porsche 924 "S"
Engine: Euro pistons, Light Flywheel, Weber TB, Bursch Header, Cam Wheel
Suspension: Front coil-overs, adj sways, Solid bush. Thicker tors. bars, 5-bolt, BBS rims
Body: Fiberglass widebody kit, 931 Nose |
QuadESL63
Posted: Sun Nov 30, 2003 7:15 am Post subject: |
| 1982Porsche924 wrote: | www.performanceproducts.com - $79.95
Part number 904271.
The main bearings are the same as the N/A 924. |
But I think those are in standard size...
Any idea? |
1982Porsche924
Posted: Sun Nov 30, 2003 1:55 pm Post subject: |
Actually, they're undersized, but it's the wrong number.
This is what my catalog shows:
924 76-77.5
STD - 904289
.25mm under - 904270
.50mm under - 904271
924 and turbo 77.5-83
STD - 904273
.25mm under - 904274
So, it looks like they don't carry it. Try www.paeco.com and give them a call. Sorry about the confusion. _________________ 1979 Porsche 924 "S"
