Stock muffler dimensions 78 n/a
timstar924
PostPosted: Fri Aug 06, 2004 4:10 pm    Post subject: Stock muffler dimensions 78 n/a Reply with quote
Anyone know the dimensions of a 78 stock muffler. I think mine is the stock muffler or at least the same size and style. It is the round style muffler. And its a north american version 924. I don't think the exhaust system was modified or anything. I'm going to measure it myself tom, but i want to be certain and get the right size. Also i'm not sure how to measure the diameter of the part that is attached to the exhaust pipe.
Vince Ponz
PostPosted: Sat Aug 07, 2004 12:12 am    Post subject: Reply with quote
If you can get a 944 muffler.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
PostPosted: Sat Aug 07, 2004 3:43 am    Post subject: Re: Stock muffler dimensions 78 n/a Reply with quote
Exhaust pipe thickness is normally 16 gauge to 14 gauge (1/16"). If the ID is inaccessible, measure the OD of your pipe with a caliper and subtract 1/8" to get the ID, but usually you'd have the exhaust pipe go inside the muffler inlet, so you'd match the OD of the pipe to the ID of the mufflet inlet.
timstar924
PostPosted: Sat Aug 07, 2004 5:52 am    Post subject: Reply with quote
i was thinking diameter of the pipe that goes into the exhaust not the thickness of the metal.
I checked lordco today one place said they don't even have a listing for a 924 muffler and another place told me its a special order and said the muffler was 850 bucks! thats so weird.
i don't know where else to check in my area, canadian tire wouldn't have one for sure.
PostPosted: Sat Aug 07, 2004 7:23 am    Post subject: Reply with quote
Those were instructions on how to measure the pipe, then figure the ID based on the OD or vise-versa by subtracting or adding the pipe thickness.
timstar924
PostPosted: Sat Aug 07, 2004 5:56 pm    Post subject: Reply with quote
i need to know the diameter of the inlet, like 2 inches 2.5 inches etc. and the exact lenght of the muffler. maybe if i just give the dimensions lordco might have one. i said porsche 924 and nothing came up in their computer and they said they just have a special order one for 850 bucks....
PostPosted: Sat Aug 07, 2004 6:19 pm    Post subject: Reply with quote
Porsche calls everything from the catalytic converter rear flange to the tip of the tailpipe the "final muffler" (comes welded together in a single piece).
Most companies that offer replacement mufflers for the 924 are going to sell the same assembly. That's probably why you got the $850 quote from Lordco.
You can probably order the Ansa OEM style "final muffler" assembly from one of a number of US suppliers for around $200US, including the shipping. The final muffler assembly is smaller enough, and light enough to be shipped by UPS. I have bought several small lots of brand new (924/944/924S/944S/951) final muffler assemblies from the local Porsche Swapmeet ($30-$40 each). I sold most all of the extra ones (sorry, no more spares) and shipped them by UPS Ground to their new owners.
If you decide to go for the "final muffler" instead of trying to replace only the rear muffler/resonator, I recommend buying the 944 final muffler 1/4" larger diameter tubing, and either adapting it to the 924 catalytic converter flange, or locating, and modifying a 944 catalytic/downpipe to fit onto the 924 downpipe output flange. This is a proven mod that should yield a 7-10hp improvement due to lower exhaust back-pressure.
A new Ansa 944 OEM style final muffler will cost you about the same amount as the Ansa 924 OEM style final muffler. It would not cost you much to have a Muffler Shop make an adapter pipe to connect to the 924 catalytic converter, if you can't locate a 944 catalytic/downpipe.
If you are trying to get away, replacing only the rear most muffler/resonator (which must be welded into place), you would be best off going to a local muffler shop, and having the local muffler expert choose a generic replacement muffler, and let him weld the sucker in. I would guess that doing it that way will cost you less than $75 US.
timstar924
PostPosted: Sat Aug 07, 2004 6:44 pm    Post subject: Reply with quote
i don't have money right now for the whole exhaust. I just wan the muffler. Lizard on this forum said he will weld on a new muffler for me if get the exact same dimension muffler so he can just remove the old one and weld the new one in. Thats why i need the inlet diameter and lenght and cirmumfrence of the muffler so i can go and ask for one at lordco and see if they have one that is the same as mine..
PostPosted: Sun Aug 08, 2004 11:59 am    Post subject: Reply with quote
get a tape measure and measure the length, then measure the diameter of the muffler at the end, as per pipe size it is PROBABLY 2" pipe but you never know what the PO may have done, I would just hold a tape up to the edge and eyeball it w/o benting the tapemeasure, if it looks close to 2" go to lordco and tell them 2" in 2" out and then approriate length and OD of the muffler, your measurements only need to be rough, they dont need a 100% accurate discription, also you dont need to tell them what car it is they wont have stuff like that in there computer, exhaust is exhaust if you own a ford or a lexus, however you dont know what PO have done so you just need to know the pipe size and muffler shape and diameter.
3 928s,
timstar924
PostPosted: Sun Aug 08, 2004 1:07 pm    Post subject: Reply with quote
it looks like a stock muffler for a 78 924 doesn't look like it was modded. it is the round style muffler.
what is od? Also i'm not sure what the lenght of the muffler is, does it inlcud the pipe the inlet pipe and the tip or just the main 'body' of the muffler.
I'm still not sure how to measure the diameter of the inlet when it is attchached to the rest of the exhaust. Isn't something like circumfrence devided by pi (math) equals the diamete. i'll try my best to meaure it and go to lordco tom morning and see if they got something.
PostPosted: Sun Aug 08, 2004 1:21 pm    Post subject: Reply with quote
OD is outer diameter. ID is inner diameter.
Yes - measure circumference and divide by 3.1415 to get the OD.
PostPosted: Sun Aug 08, 2004 1:23 pm    Post subject: Reply with quote
I dont care if it looks factory a good exhaust person can make it look factory, also I highly doubt that it is the origonal muffler from 1978! dont go by looks always
timstar924 wrote:
what is od?
Overall Diameter
just the BODY and tell that to Lordco
Just hold the tape upto it and EYEBALL it if it looks like it is 2 1/2" tell them that if it looks like 2 1/4" tell them that, just hold a tape measure up against it and LOOK at the tapemeasure to see roughly how big the diameter is, I will be coming over pretty early probably around 9:00am and you will also need something to get the old muffler off with probably a hacksaw.
as I said I will be over early because I have alot to do tomorrow as it is my last day down here at the coast. also we will need probably an 8mm allen key to remove the door from the car so that I can fix its closing problem.
3 928s,
timstar924
PostPosted: Sun Aug 08, 2004 1:39 pm    Post subject: Reply with quote
i won't be able to get the muffler before 9am... Not even sure when lordco opens.
timstar924
PostPosted: Sun Aug 08, 2004 1:40 pm    Post subject: Reply with quote
should i go buy a hack saw too or do you got one already?
PostPosted: Sun Aug 08, 2004 1:43 pm    Post subject: Reply with quote
actually I talked to Kenodog and he said he has a hacksaw but doesnt know how good the blade is so you may have some tough cutting to do, lordco should open at 9:00am so I will say 9:20am then.
3 928s,
