Cam Cover
Stu2j
PostPosted: Fri Jun 06, 2003 11:59 am    Post subject: Cam Cover Reply with quote
How hard is it to swap the cam cover on the 924?
In addition to the new cover do you just need a new gasket? Does the gasket have to be treated with something?
Is this a simple thing or a big complicated thing?
Thanks.
-Stu
924 owner since 1988
924S owner since 2002
Click here to view them:
924 turbo
PostPosted: Fri Jun 06, 2003 12:22 pm    Post subject: Reply with quote
It's a pretty easy job. The only things to watch out for are the little nuts and washers that hold the cam cover on. They're quite small and easy to lose, so be careful when you take them off. Once you have the cover off, it's a good time to inspect the plastic elbow on the oiling tube and peek at the cam lobes and followers to make sure they're wearing evenly. I don't use any sealant of any kind on the valve cover.
Jon Furst
924martinirossi
PostPosted: Fri Jun 06, 2003 1:29 pm    Post subject: Reply with quote
I have been sucessfull more times than one on resusing the old gasket. Should be no problem.
Michael
PostPosted: Fri Jun 06, 2003 3:21 pm    Post subject: Reply with quote
Dont attempt it look for a mechanic and tell him you want a new gasket.
Stu2j
PostPosted: Fri Jun 06, 2003 11:21 pm    Post subject: Reply with quote
Why shouldn't I attempt it?? Please elaborate
-Stu
78 924 N/a
PostPosted: Sat Jun 07, 2003 6:22 am    Post subject: Reply with quote
Its really easy. Why though, did you get a polished cover? Or is it leaking?
You 'should' use a new gasket. You might be able to get away with it but why bother?
Just make sure you do a really good surface prep (clean, and dry) before you put new gasket on! Don't put anything on gasket!
924 Turbo is right about the cam feed elbow BUT for your own peace of mind, you should replace the elbow and the tube. Very cheap insurance!! They are on ebay all the time, although prolly avail. just about anywhere. VERY CHEAP insurance!!
1978 924 n/a
PostPosted: Sat Jun 07, 2003 7:10 am    Post subject: Reply with quote
whats with the avitars martinirossi is pretty hip though pop-eye
movies thats something else Kind of got a kick out of them at first
then watched awhile thought" hmm" isnt that something a mini-
movie avitar.
78 924 N/a
PostPosted: Sat Jun 07, 2003 7:17 am    Post subject: Reply with quote
That avatar is pretty cool Stu! Where'd you find that?
1978 924 n/a
78 924 N/a
PostPosted: Sat Jun 07, 2003 7:18 am    Post subject: Reply with quote
And how come your not at work Joe, hookie???
1978 924 n/a
Stu2j
PostPosted: Sat Jun 07, 2003 11:24 am    Post subject: Reply with quote
You are on the information superhighway. Do a google search for "animated avatars".
I was going to use a NASCAR one but the "super mechanic" was just too good to pass up
-Stu
Stu2j
PostPosted: Sat Jun 07, 2003 11:26 am    Post subject: Reply with quote
I'm thinking about trading mine for a polished one
-Stu
Stu2j
PostPosted: Fri Jun 13, 2003 10:15 am    Post subject: Reply with quote
Wow.. look what I got CHEAP!!
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&category=33627&item=2418385187
Hmmm.. might make the rest of the engine look pretty crappy eh?
-Stu
Minus000
PostPosted: Fri Jun 13, 2003 11:16 am    Post subject: Reply with quote
cool. let me know how it goes. I saw that this moring browsing for a shifter boot. Maybe I will buy one next.
1982Porsche924
PostPosted: Sat Jun 14, 2003 5:47 am    Post subject: Reply with quote
takes me 10 minutes to take off, really easy. Make sure to get both the valve cover gasket and 2 seals. I ordered seals from performance, only to find out that it comes in a pack of 1. As Jon already said, make sure to keep track of those little nuts, they are fairly easy to loose. Good deal on that valve cover, really nice. Make sure to get pictures once you install it.
might want to check your valve clearances once the valve cover is off...just in case.
1979 Porsche 924 "S"
Engine: Euro pistons, Light Flywheel, Weber TB, Bursch Header, Cam Wheel
Suspension: Front coil-overs, adj sways, Solid bush. Thicker tors. bars, 5-bolt, BBS rims
Body: Fiberglass widebody kit, 931 Nose
Phogphire1
PostPosted: Tue Jun 17, 2003 7:35 am    Post subject: Reply with quote
Hey Stu2j, You got yours cheaper than I got my beadblasted. pretty cool.
I think I paid $15 to have mine beadblasted (packaged other parts as well)
Good move,
Jonathan
Extremism in the defense of liberty is no vice. And moderation in the pursuit of justice is no virtue.
Life, Liberty and the Pursuit of thoose that dare screw with it.
