CBass
Posted: Tue Oct 14, 2003 2:00 pm Post subject: measuring 931 combustion chamber |
Has anyone previously measured the 931 combustion chamber before, and still have the numbers kicking around?
If not, I'm going to attempt this with a 10cc syringe, laser level, and alot of eyeballing to make sure the water level doesn't rise above the chamber.
Any comments, advice or questions before I do this? _________________ '81 931 in various states of assembly |
78 924 N/a
Joined: 20 Mar 2003 Posts: 769 Location: Pacific N.W.
Posted: Tue Oct 14, 2003 3:04 pm Post subject: |
Don't need the laser level. Use a flat piece of plexiglass with a small hole drilled in it for adding liquid. Seal plate to the head lightly w/ grease. Don't forget to take the valves out and grease the sealing edges. Wipe off any excess grease. And of yeah, don't use water. Try de-natured alcohol.
HTH's  _________________ 1978 924 n/a |
CBass
Posted: Wed Oct 15, 2003 12:22 am Post subject: |
I was going to use the level to make sure the head was perfectly level, but I guess it wouldn't have to be if I used your plexiglass technique I have plexi and axle grease in abundance, so I'll try this today.
As for the valves, the total combustion chamber volume will include the valves, and the head I'm using was from a parts car with a blown headgasket, so I'm not too worried about a little water getting in there.
Stay tuned  _________________ '81 931 in various states of assembly |
-nick
Posted: Wed Oct 15, 2003 1:32 am Post subject: |
Let us know! I'm waiting in anticipation to work out the numbers...
-nick |
kaffine
Posted: Wed Oct 15, 2003 5:35 am Post subject: |
Add color to the liquid to make it easier to see. _________________ 80 924
80 931
The best desciption of an atom boils down to something unknown is doing we don't know what.
Sir Arthur Eddington |
