Do I have a Performance Part and not know it ???
Wiz-PORSCHE-924
PostPosted: Thu Sep 18, 2003 11:35 am    Post subject: Do I have a Performance Part and not know it ??? Reply with quote
The Throttle body on my 78 on the side it says REDLINE and WEBER on the top. Is this OE ??
Zuffen
PostPosted: Thu Sep 18, 2003 12:06 pm    Post subject: Reply with quote
no it is aftermarket and somewhat sought after but not necessarily rare....
Bob Dodd - 924turbo@cox.net
931 1982, 944 1982 euro, 924S 1988SE, 93 968 tip 06 Silver Cayenne S, 06 Black Cayenne S
I have Way too many cars, parts for the 931,944 and 951
Wiz-PORSCHE-924
PostPosted: Fri Sep 19, 2003 11:56 am    Post subject: Reply with quote
So Who made it and is it any better? How ?
78 924 N/a
PostPosted: Fri Sep 19, 2003 12:34 pm    Post subject: Reply with quote
Weber. Wanna sell it?
1978 924 n/a
jpab924
PostPosted: Fri Sep 19, 2003 1:59 pm    Post subject: Reply with quote
The Weber t-body is a single big bore.
I don`t know the exact measurements, but it is plenty bigger than the stock double barrel t-bodies.
Theory is, a bigger bore means less restriction. So, you get more air into the cylinders. You can run richer, and pack in more of a "charge" into the cylinders. This means more power.
I haven`t seen any proof that this t-body does any good. Other than a few testemonials I`ve read here.
78 924 N/a
PostPosted: Fri Sep 19, 2003 2:12 pm    Post subject: Reply with quote
Its been said by some to have a somewhat improved throttle response. Peak gains are said to be non-existent, as is with almost all bolt-ons.
I also have not ever seen any "real" tests done with a Weber tb.
1978 924 n/a
Roger
PostPosted: Sat Sep 20, 2003 2:00 pm    Post subject: Reply with quote
Best I can tell is that the larger throttle body yealds about 3-5 hp at best but you sould have better throttle response.
1981 924 NA
PostPosted: Sat Sep 20, 2003 3:04 pm    Post subject: Reply with quote
Is that so Roger [didnt I get you a pet cd]
Heres a testimonial [a short one]
Whats cool is you can get on the power band and with other mods
you can have some fun by opening it real fast it gives pretty quicke response.
Away from that I can see where right after my paint job
is done Im gonna [maybe] pull the motor and up th cp
[10-1] have the head checked for straightness figure if
I can set it up for quicke turn out from the machine shop
that would work..and while I waite [I doute it though]
replace the 1 st gear synchro 016z while there do them
all if they need it for me though its best if I buy a used
one for $300.00 and just take my time and install it
when its finished. The one I have is fine it just doesnt
like to go into 1st when rolling.
Hold on to the TB I got mine from Jpab in Indiana.
who should of kept it. I like it alot.
Roger
PostPosted: Sun Sep 21, 2003 2:13 am    Post subject: Reply with quote
Thanks Joe, I do appreciate it but I never got it to work, oh well. I did get a whole bunch of reference and tech stuff though. I did not mean to make it sound like the larger throttle body was not worth it. I like the idea. Its just not a huge HP gain.
1981 924 NA
