Rear View Mirror Placement
Doodle
PostPosted: Tue Sep 23, 2003 1:45 pm    Post subject: Rear View Mirror Placement Reply with quote
I wonder if anyone would be so kind as to take a measuring tape and check the distance from the rear view mirror mount to either side and top to bottom of the windshield. I need to get the car through an insurance inspection and have to install the rear view mirror on a new windshield after the body shop broke the original. I don't believe the mirror is centered side to side and know it's not, top too bottom. The correct measurements would simplify this detail.
Doodle
Pre 77.5 Mars Red
78 924 N/a
PostPosted: Tue Sep 23, 2003 4:45 pm    Post subject: Reply with quote
If it helps, flip the visors most of the way down and place mirror as to not interfer with them during movement.
1978 924 n/a
Doodle
PostPosted: Wed Sep 24, 2003 12:59 am    Post subject: Reply with quote
Thanks 78 924 N/a. Your suggestion would definitely work the best except I haven't installed the visors as yet. When the car was in the body shop I had a hole cut in the roof to accomodate an aftermarket sun roof. The sun roof installer's challange will be to fabricate a new headliner which compliments the rest of the interior. In order to facilitate his task I thought it easiest to just provide all the parts and let him assemble them. My challenge is to get the car too him. I have to first get the car through an insurance safety inspection which requires all mirrors to be in place. Once this is done I can get the car insured and registered which will help with my challenge.
It would sure help if someone was willing to take a few minutes and a measuring tape and could provide the correct measurements. Any takers?
Doodle
Pre 77.5 Mars Red
PostPosted: Wed Sep 24, 2003 1:15 am    Post subject: Reply with quote
OK, it's centered left-right (as you might expect), and 4.75" down (that's a measurement to the center of the mounting "dot" from the outer windshield trim. I measured it on the outside.
You may find, to get a good center, that the dome light provides the best reference. My mirror is centered on it.
Which car to buy?
PostPosted: Wed Sep 24, 2003 1:48 am    Post subject: Reply with quote
Why do you need the rear view to pass inspection? In Canada you just need two side mirrors, right? I had this problem a few years ago, and passed without it. Call ahead to see if you need it.
Doodle
PostPosted: Wed Sep 24, 2003 1:53 am    Post subject: Reply with quote
Thanks again Vaughan. Hope it wasn't too much of an inconvenience. I now have the necessary reference points to deal effectively with this detail. Not likely, but hopefully one day I'll be able to return the favour in some small way.
Doodle
Pre 77.5 Mars Red
Doodle
PostPosted: Wed Sep 24, 2003 2:06 am    Post subject: Reply with quote
My insurance company provided me with a form to have filled out by a Mechanic licensed too do inspections. My mechanic of choice feels that if this form asks specifically about number and placement of rear view mirrors they consider them to be a safety item and he's not prepared to risk his license over what he considers to be an easy fix. Besides, sometimes it would be nice to have a bigger picture of everything that is behind me. Motorcycles provide a perfect example in my mind of the kind of vechicles side mirrors alone may not detect behind me. I guess to answer your question I'm anal enough to think this is important.
Doodle
Pre 77.5 Mars Red
Which car to buy?
PostPosted: Wed Sep 24, 2003 2:21 am    Post subject: Reply with quote
I would replace it as well, but if you didn't need it for inspection you could leave it last on the list.
PostPosted: Wed Sep 24, 2003 2:51 am    Post subject: Reply with quote
No problemo! My car was sitting right outside...
PostPosted: Wed Sep 24, 2003 3:38 am    Post subject: Reply with quote
if the car didn't come with it, then it doesn't need it!!, that is how it is here in BC anyway
3 928s,
