Porscheaddiction
Joined: 03 Nov 2002 Posts: 431 Location: Cornwall, Ont, Canada
Posted: Tue Aug 12, 2003 1:22 am Post subject: Door adjustment |
Hey all my passenger side door needs to be adjusted a bit actually needs to be moved back a tiny bit. Can one person do this or should the wife help out? Looks like all that needs to be done is to losen off the 4 bolt hinges and slide the door am I correct on this assumption? I am just looking to move the door back abit and dont need to touch the hight of it at all.
Thanks Chris. |
wdb
Doodle
Joined: 25 Nov 2002 Posts: 225 Location: Comox Valley, B.C. Canada
Posted: Tue Aug 12, 2003 3:45 pm Post subject: |
I found it to be a difficult job for just one person. Though they are relatively small doors I believe the addition of the substantial side impact beams etc. make them heavy and unwieldy to adjust by yourself. There's quite a bit of adjustment in and out and a relatively small amount of adjustment forward and back. You're dealing with a round pin (bolt) in a slightly larger square hole. Atleast this is what I found with my car. _________________ Doodle
Pre 77.5 Mars Red |
