law-guy
Joined: 05 Nov 2002 Posts: 29 Location: Oklahoma City
Posted: Sun Aug 10, 2003 2:33 pm Post subject: question on new air intake boots |
I have a 1979 924 and I have just purchased new intake boots. I put the new boots on and now the car wont start. I think that the problem is that on one of the new boots, the boot that attaches onto the air filter box, there is an outlet about 1 inch long that looks like something should attach to it. My old boot did not have this outlet thingy. I am thinking about just plugging the outlet with a screw or something, but I was wondering if I got the wrong part or if something is supposed to attach there.
Thank you -- brian |
924martinirossi
Joined: 04 Nov 2002 Posts: 605 Location: Seattle, Washington, USA
Roger
Posted: Mon Aug 11, 2003 5:50 am Post subject: |
My 81 has it. It connects to a plastic part (probably some sort of valve) then the plastic part conects to a vacuum line that goes to the intake and connects right by the cold start valve. I couldnt tell you what it does though. _________________ 1981 924 NA
augidog
Posted: Mon Aug 11, 2003 11:19 am Post subject: |
mine is plugged with a bolt and clamp.
I would do the same on yours for starters. _________________ 1978 924 95 mile daily driver.
78 924 N/a
Joined: 20 Mar 2003 Posts: 769 Location: Pacific N.W.
Posted: Mon Aug 11, 2003 1:20 pm Post subject: |
| augidog wrote: | mine is plugged with a bolt and clamp.
I would do the same on yours for starters. |
Then try to find the right boot for your application. _________________ 1978 924 n/a |
Doodle
Joined: 25 Nov 2002 Posts: 225 Location: Comox Valley, B.C. Canada
Posted: Tue Aug 12, 2003 3:59 pm Post subject: |
My '77 came without the outlet. The replacement boot came with the outlet. I plugged the outlet with a bolt and hose clamp. It works fine. I believe the old style boot without the outlet has been superceeded to the boot with the outlet. _________________ Doodle
Pre 77.5 Mars Red |
