RE Phantom grip LSD
turbobob9242
PostPosted: Wed Aug 20, 2003 10:43 am    Post subject: RE Phantom grip LSD Reply with quote
HI everyone.
I sent an email to the Phantom grip LSD people ad it looks like a nice alternative to the more expensive Quaiffe or Guard units.
Here is copy of the email and reply:
dear sir
the phantom grip 944 units have been tested over 500 whp and torque.
thank you
phantom grip
> This is a multipart message in MIME format.
> I have a hybrid car making way more than stock horsepower and
torque.
> How much torque can your LSD unit support??
> My application has a 86 944 turbo transmission.
> I estimate I have around 400 ft lbs of torque!
> I look forward to hearing back from you as I am very interested in
adding
> LSD to my car!
> WOW, 500 HP and or Torque!!!!
Bob Ward
80 9214 turbo, w 5.3 LS V8
Alex Roy
PostPosted: Thu Aug 21, 2003 7:09 am    Post subject: Reply with quote
They said it has been tested at 500 hp and torque.......they never said it didn't fail with that much power
Just kidding.
PostPosted: Thu Aug 21, 2003 7:56 am    Post subject: Reply with quote
you pay for what you get the Quaiffe is a much better designed unit and will not destroy the internals of the tranny, not saying that the Phantom grip LSD unit will though
3 928s,
PostPosted: Thu Aug 21, 2003 10:18 pm    Post subject: Diff options Reply with quote
Yeah, works great till it trashes the spider gears. A 951LSD is a cheaper alternative and will bolt into the 5-speed 924 trans (or the 931 trans), excluding the snailshells (which should use a 911 diff). They can sometimes be had for $500, though you can pay retail up to $1000USD. Quaifes are available new retail for $1200 or so from OG Racing (www.ogracing.com IIRC).
CBass
PostPosted: Sat Aug 23, 2003 5:53 am    Post subject: Reply with quote
Has anyone actually used a 911 differential in a snailshell, or is this just theory?
I've read that the snailshell was based off the 915 tranny, but are the differentials interchangeable? Maybe we should start comparing part numbers
keith
PostPosted: Mon Sep 22, 2003 7:23 am    Post subject: Reply with quote
I know for a FACT that the phantom grip is ineffective in a 340rwhp 951.
I know because we installed it in a customer's car and tested it.
keith
86/9 951
the RUNT.
PostPosted: Mon Sep 22, 2003 7:25 am    Post subject: Reply with quote
the 930 lsd Diff will work in the G31
3 928s,
CBass
PostPosted: Mon Sep 22, 2003 7:31 am    Post subject: Reply with quote
Has this been documented? If so, great, if not, I don't want to be the guy who spends $1200 on a GT or Quiafe diff and find out I'm gonna get soaked for a few hundred if it doesn't work and I need to resell it...
Also, I'd be looking for a lower ratio than the stock 4.7:1... My goal is to use a 9000rpm engine, so I'd want a lower final drive ratio.
PostPosted: Tue Sep 23, 2003 8:01 am    Post subject: Reply with quote
So like can we usea 911 diff and
would we want to is it a reaping
upgrade if so what years the same
years as the snailshell.
turbobob9242
PostPosted: Tue Sep 30, 2003 10:00 am    Post subject: 9000 RPM engine?? Reply with quote
Are you using a motor cycle engine??
Never head of anything other than Mazdo Wankle engine or motor cycle engines reving to 9000 on the street.
Bob Ward
PostPosted: Tue Sep 30, 2003 10:02 am    Post subject: Re: 9000 RPM engine?? Reply with quote
where did you get that from???
also the Honda S2000, has a 10,000 rpm rev limit
3 928s,
Porschephile
PostPosted: Tue Sep 30, 2003 11:16 am    Post subject: Reply with quote
the S2000 uses a motorcycle engine.
werd B.
