Darin81T
Posted: Thu Sep 04, 2003 4:48 am Post subject: 1981 DTIC pinout |
I found a wire that appears to be broken off of the connector to the DTIC. Does anyone have the pinout for the connector so I can find out what pin to solder it to?
Thanks,
Darin Flynn
1981 931 |
924 turbo
jamez
Joined: 03 Nov 2002 Posts: 401 Location: Chehalis, Wa
Posted: Fri Sep 05, 2003 5:28 am Post subject: |
| Do different years cars have different colored wires in the 12 pin connector? because I pulled it apart and some of the wires were different colors than that post says.. all of them are the same except the green(tach I think) wire isnt there and there is a brown/red wire in there which isn't listed. |
924martinirossi
Joined: 04 Nov 2002 Posts: 605 Location: Seattle, Washington, USA
Posted: Fri Sep 05, 2003 1:14 pm Post subject: |
Is this the 81 you just bought from me? Look in the factory manuals I gave you. Also I can foward you a 4 page wiring diagram of the engine electricals.
Michael |
924martinirossi
Posted: Fri Sep 05, 2003 1:22 pm Post subject: |
I justed looked at my wiring diagram of the 81 turbo and the wires to/from the DITC are as follows:
Pin 3 grn/wht (to transistor ingition unit)
Pin 7 brn/wht (to transistor ingition unit)
Pin 11 blk (connected to fuel pump relay)
Pin 12 brn and brn/red (this wire goes to the air intake temp sensor) I replaced this device this year thinking that what was causing the hunting idle)
Pin 9 brn/black (to one side of the air intake temp switch)
Pin 5 wht/blu (to throttle switch)
Pin 13 blk (to pulse generator)
Pin 14 yel (to pulse generator)
Pin 15 ground sheild for pulse generator
Michael |
jamez
Posted: Fri Sep 05, 2003 6:39 pm Post subject: |
| Thanks Michael, the Brn/red wire on pin 12 came disconnected, although there is no noticable difference with it soledered back on now... hmm |
924martinirossi
Posted: Sat Sep 06, 2003 4:50 am Post subject: |
Under the front cross member there is a black single wire plug that goes to the Oxygen Sensor. Disconnect that and see if the idle on the car hunts.
I do have a sensor tester that I have hooked up to it and it tested fine. However after the idle problem I retested the sensor and did not get a correct reading, maybe due to the broken wire.
Let me know.
Michael |
924 turbo
Posted: Sat Sep 06, 2003 10:27 am Post subject: |
What is the car doing that isn't normal? _________________ Jon Furst |
