wiring harness
924ttrouble
PostPosted: Sun Jul 13, 2003 2:57 pm    Post subject: wiring harness Reply with quote
Will a wiring harness from a 1987 944 fit a 1982 924 turbo?
PostPosted: Sun Jul 13, 2003 3:12 pm    Post subject: Reply with quote
please lay off the ganja
3 928s,
924 turbo
PostPosted: Mon Jul 14, 2003 12:12 am    Post subject: Reply with quote
Almost everything is different. Some of the body sections are probably similar, but the interior and engine harnesses aren't going to be of much use to you.
Jon Furst
924ttrouble
PostPosted: Tue Jul 15, 2003 9:59 am    Post subject: Reply with quote
No I refuse to lay off the ganja you can do anything with some created wire work, don't you think. A wiring harness for this car is so hard to find it's almost impossible to locate and you can't buy one new at least I don't think you can?
PostPosted: Tue Jul 15, 2003 9:54 pm    Post subject: Reply with quote
I don't see how they'd relate remotely. Start from scratch, you'd be in better shape. And yes, it is possible to rebuild sections of the harness.
