n4bbq
Joined: 03 Jul 2003 Posts: 10 Location: Dahlonega, Ga
Posted: Fri Jul 18, 2003 1:48 am Post subject: Part Number Needed - 1981 931 - Vacuum Line |
It is the vacuum line coming from the WUR to a Tee above the intake. It is about 5-6 inches long with the metal clamps on each end.
Thanks for any help |
-nick
Posted: Fri Jul 18, 2003 2:23 am Post subject: |
any bulk vacuum linefrom your local parts shop will do. just make sure the inner diameter matches up. the metal clamps at the ends can be replaced with regular hose clamps. no sense going to the dealer for it.
-nick |
924martinirossi
Joined: 04 Nov 2002 Posts: 605 Location: Seattle, Washington, USA
Posted: Fri Jul 18, 2003 6:15 am Post subject: |
The new vaccume hose (from a VW shop) is metric sized and cloth covered, just like stock. The metal clips I removed and squeezed back on to look stock.
The shop where I buy fittings from even has an assortment of the clamps that Porsche used on the vaccume lines and in-tank pump.
Michael |
