Peter
Joined: 04 Nov 2002 Posts: 379 Location: New York, NY
Posted: Tue May 06, 2003 11:43 am Post subject: 931 to 937 |
The latest issue of 9 Magazine has a 2 page spread of a man who coverted his 931 to a 937 replica, with 937 intercooler, flares, headlights, interior --the whole package. Some nice picks of cutting the rear quater panels, and other fabrication he did. Good issue to buy and save.
Strange how these people are not on this board?
-Peter
PS the latest issue of GRM has some interesting articles on dyno's, how to read them, how not to be fooled by high HP numbers, etc. Another good issue to buy and keep |
sandgroper
Posted: Mon Jul 14, 2003 3:01 am Post subject: |
| peter,is it the may issue,i would like to get it,thanks |
epsylon
Joined: 05 Nov 2002 Posts: 492 Location: South Padre Island, Texas
Posted: Mon Jul 14, 2003 5:23 am Post subject: |
yes, i would love to see the article as well. anyone have the issue and a scanner? we could easily find a place to host the pictures for people to review and read. _________________ '82 931
'78 928
Howell Henderson
South Padre Island |
Posted: Mon Jul 14, 2003 5:33 am Post subject: |
hey epsylon, is your distributor sitting properly, it looks like it might be sitting to high, IE mounted on wrong holes. if it is sitting like this the cap will hit the hood _________________ 3 928s, |
924 turbo
Joined: 02 Nov 2002 Posts: 1566 Location: Simi Valley, CA, USA
Posted: Mon Jul 14, 2003 7:46 am Post subject: |
Ditto what Lizard says. Good eye, Lizard! _________________ Jon Furst |
epsylon
Posted: Mon Jul 14, 2003 10:17 am Post subject: |
yes either the PO or his mechanic mounted it wrong 180 degrees and it does just barely hit the hood. i have not had time to mess with it. it does not effect drivability that i am aware of. i just have to be carefull when closing the hood. _________________ '82 931
'78 928
Howell Henderson
Posted: Mon Jul 14, 2003 11:46 am Post subject: |
let me put it this way, CHANGE IT NOW, the hood will hit it and break the spark plug wire and the cap, one day you will go to start it and it wont start, then you will open the hood to see what is wrong and you might spot it right away you might not, but it will casue the car not to start or run REALLY poorley, so do it now so you don't have to worry about it. _________________ 3 928s, |
epsylon
Posted: Wed Jul 16, 2003 12:29 am Post subject: |
i will try and get to it this weekend. relocating the distributor means ordering a new valve cover gasket which was why i havn't messed with it yet.
let me make sure i understand what needs to be done though. it is mounted in the wrong mounting holes seating it too high and not the 180 degrees out of phase that is cuasing it to almost hit the hood, correct? _________________ '82 931
'78 928
Howell Henderson
Posted: Wed Jul 16, 2003 2:07 am Post subject: |
basically you undo and remove 3 bolts, you then slide it back take of the old gasket lay the new one down put it back on andput the bolts in the right holes this time and screw down, dont over tighten aluminum head will strip easy. but with it in its current position, it is probably hitting the hood, unless your hood is siting alittle high. _________________ 3 928s, |
epsylon
Posted: Fri Jul 18, 2003 12:33 am Post subject: |
gee thanks. you made me look really lazy.  _________________ '82 931
'78 928
Howell Henderson
78porsche924
Joined: 14 Dec 2002 Posts: 1217 Location: Newark, DE(near where DE,MD and PA meets)
Posted: Sat Jul 26, 2003 5:48 am Post subject: |
Also vaughn mentioned some people haveing problems of the spark plug wires arcing to the hood when it is in the right spot. You might be having this with the dizzy toughing the hood. _________________ 90 944 S2
78 924 NA <---now sold and killed by new owner
snailshell trans
Bae turbo kit
to check out my 944 S2 http://www.cardomain.com/member_pages/view_page.pl?page_id=388139 |
Posted: Sat Jul 26, 2003 6:35 am Post subject: |
Whats with the metal cup around the cap,I picked one up from an 80
Also the bolts are ruff to get to on the dizzy mount. Ijust picked the p .excellence mag with the US lega redl 959 the cover.Whats the address for nine mag. So I can pick up a sub. wasnt someone from the board
involved with the mag I remember reading about it. awhileback on this here board. Pm me the address for a sub. I cant find it around here I dont think. Sound s like agood article . _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
sandgroper
Posted: Mon Jul 28, 2003 1:56 am Post subject: |
| good news,go to www.9magazine.com and order back issue vol2 no1,$5.99. |
TonD
Joined: 26 Jul 2003 Posts: 72 Location: Rotterdam, Holland
Posted: Thu Jul 31, 2003 1:53 am Post subject: |
USA orders only So, the search for someone with the magazine AND a scannner continues  _________________ Just remember I aint American nor English, so please don't blame my language  |
J1NX3D
Joined: 06 Feb 2003 Posts: 1333 Location: New Zealand
Posted: Tue Aug 05, 2003 6:02 am Post subject: |
im keen to have a look also. there are interior differences between 931/ 937? what are they? _________________ '86 944 |
