I think I figured out my problem !!
Wiz-PORSCHE-924
PostPosted: Thu Jun 26, 2003 5:50 am    Post subject: I think I figured out my problem !! Reply with quote
I think I might have figured ot why my 1978 924 wont start. When It was running the timing belt was squeaking bad, and I think that is why my Porsche always sound like it was going to stall at idle.
So I went out and bought a timing light, and I will try to see if that is hopefully the problem. Im thinking the Belt is bad. Any tips or suggestions for me ??
PostPosted: Thu Jun 26, 2003 6:02 am    Post subject: Reply with quote
the timing belt itself wont squeek but the timing belt tensioner will, check out joes post he seems to like to break them he will know where to get one, but wouldn't hurt to change the belt at the same time
3 928s,
Wiz-PORSCHE-924
PostPosted: Thu Jun 26, 2003 10:55 am    Post subject: Reply with quote
Is that an easy fix ?
78 924 N/a
PostPosted: Thu Jun 26, 2003 11:57 am    Post subject: Reply with quote
Fairly.. if your mech. inclined, VERY.
1978 924 n/a
1982Porsche924
PostPosted: Sat Jun 28, 2003 5:00 pm    Post subject: Reply with quote
Yeah, timing belt squeek is most likely from shot bearings in the tensioner. Take a long screwdriver, and put it on the bolt of the tensioner while the car is on(or any non-moving part of the tensioner). Then put your ear to the screwdriver, if it's the same sound, it's the actual tensioner. Also, you say that you bought a timing light, but that's for ignition timing, not cam timing.
1979 Porsche 924 "S"
Engine: Euro pistons, Light Flywheel, Weber TB, Bursch Header, Cam Wheel
Suspension: Front coil-overs, adj sways, Solid bush. Thicker tors. bars, 5-bolt, BBS rims
Body: Fiberglass widebody kit, 931 Nose
Wiz-PORSCHE-924
PostPosted: Mon Jun 30, 2003 12:18 am    Post subject: Reply with quote
I cant do anything when the car is on, Because it wont start.
