bigsteve1983
Posted: Thu Jul 24, 2003 1:57 am Post subject: 944S2 Head on 924 engine |
| Is it possible for a 944S2 head or 968 head to fit on a 924 engine in order to create more power and airflow characteristics? |
81turbo
Joined: 03 Nov 2002 Posts: 1065 Location: Oakland, CA
Posted: Thu Jul 24, 2003 2:42 am Post subject: |
| No way in hell. |
78porsche924
Joined: 14 Dec 2002 Posts: 1217 Location: Newark, DE(near where DE,MD and PA meets)
Posted: Thu Jul 24, 2003 1:22 pm Post subject: |
The bore is 106mm on the s2 and on the 924 is is i believe 86mm(not positive but pretty sure). Anyway it is a big difference. Even if you could, how would u do the timing belt? The s2 uses a high tension timing belt and has to be exact(interference engine). I assume you would have to keep it interference in order to get a high enough CR. The actual engine block of the 944 s2 is also much much bigger.The dohc with the 16 valves(or 16ventiler as it says on the side of the car) would be sweet on a 924 though. _________________ 90 944 S2
snailshell trans
Bae turbo kit
to check out my 944 S2 http://www.cardomain.com/member_pages/view_page.pl?page_id=388139 |
Posted: Fri Jul 25, 2003 8:37 am Post subject: Re: 944S2 Head on 924 engine |
| bigsteve1983 wrote: | | Is it possible for a 944S2 head or 968 head to fit on a 924 engine in order to create more power and airflow characteristics? |
Are you referring to a 924S? |
