78 924 N/a
Joined: 20 Mar 2003 Posts: 769 Location: Pacific N.W.
Posted: Sat May 10, 2003 5:10 am Post subject: Sunroof Deflector...ENDS |
Hi, I just bought a new sunroof deflector, but REALLY what I NEEDED was the ends that screw to it. The passenger side is broken on my old one, and the drivers side is nicely cracked. Of course, the new deflector did't come with these ends, BUT it's not warped like my old one either Does anyone know where I can find these?? _________________ 1978 924 n/a |
augidog
Posted: Mon May 12, 2003 1:06 am Post subject: |
where did u get your deflector?I need one also. _________________ 1978 924 95 mile daily driver.
Roger
Posted: Mon May 12, 2003 1:05 pm Post subject: |
I am not sure what you are asking. The deflector is one peice what ends are you refering to. _________________ 1981 924 NA
J1NX3D
Joined: 06 Feb 2003 Posts: 1333 Location: New Zealand
Posted: Mon May 12, 2003 1:52 pm Post subject: Re: Sunroof Deflector...ENDS |
| 78 924 N/a wrote: | | Hi, I just bought a new sunroof deflector, but REALLY what I NEEDED was the ends that screw to it. Does anyone know where I can find these?? |
I know what you mean. if you can hang tight im going to get my sunroof welded out and freeing up all those parts. I had to buy a left hand part of what you're speaking of after a drunk mate stood thru my sunroof and leaned on the deflector and broke it my deflector would be up for sale too augidog  _________________ '86 944 |
Posted: Tue May 13, 2003 1:54 am Post subject: |
ok the parts he is speaking of is the deflector hinges, go to the dealer or www.performanceproducts.com
they have 2 bolts, and nuts that go onto either end of the deflector, they crack and break with age _________________ 3 928s, |
78 924 N/a
Posted: Tue May 13, 2003 3:57 am Post subject: |
Yeah, they have two phillips head screws with nuts on other side attach deflector to hinge?
Liz, checked with performance parts, have price of $6.95, but do NOT stock????  _________________ 1978 924 n/a |
Posted: Tue May 13, 2003 4:28 am Post subject: |
have you tried contacting the Porsche dealer in your area _________________ 3 928s, |
78 924 N/a
Posted: Tue May 13, 2003 7:19 am Post subject: |
no, not really sure where one is, probably Seattle is closest, last ditch effort _________________ 1978 924 n/a |
Posted: Tue May 13, 2003 7:22 am Post subject: |
| 78 924 N/a wrote: | | no, not really sure where one is, probably Seattle is closest, last ditch effort |
try www.porsche.com to find dealer locations _________________ 3 928s, |
78porsche924
Joined: 14 Dec 2002 Posts: 1217 Location: Newark, DE(near where DE,MD and PA meets)
Posted: Tue May 13, 2003 7:34 am Post subject: |
You can fix them with a little superglue. I did that to mine and it worked, but it was warped and caused the sunroof to leak grrrrrrrr. I have an aftermarket one that the PO put on there so i just took mine out. _________________ 90 944 S2
snailshell trans
Bae turbo kit
to check out my 944 S2 http://www.cardomain.com/member_pages/view_page.pl?page_id=388139 |
78 924 N/a
Posted: Tue May 13, 2003 8:13 am Post subject: |
Thanks Lizard for the porsche link. Hopefully thats all the help I'll need, unless someone has the right part #/ official name?? _________________ 1978 924 n/a |
Posted: Tue May 13, 2003 8:23 am Post subject: |
it is called the sunroof deflector hinge, there is a left and right part #, but I don't have them sorry _________________ 3 928s, |
1982Porsche924
Joined: 14 Nov 2002 Posts: 679 Location: Cupertino, CA
Posted: Tue May 13, 2003 10:55 am Post subject: |
Ah the joys of no sunroof.  _________________ 1979 Porsche 924 "S"
Engine: Euro pistons, Light Flywheel, Weber TB, Bursch Header, Cam Wheel
Suspension: Front coil-overs, adj sways, Solid bush. Thicker tors. bars, 5-bolt, BBS rims
Body: Fiberglass widebody kit, 931 Nose |
78porsche924
Posted: Tue May 13, 2003 11:02 am Post subject: |
Must not be much joys. Nothing like flying over 70 witht he sunroof off. Almost feels like you have a convertable. _________________ 90 944 S2
snailshell trans
Bae turbo kit
1982Porsche924
Posted: Tue May 13, 2003 11:07 am Post subject: |
Nothing like no leaks and more structural integrity. _________________ 1979 Porsche 924 "S"
