noisy bonnet
ltgland
Location: London (that England, Europe for the geographically declined)
PostPosted: Tue May 13, 2003 7:06 am    Post subject: noisy bonnet Reply with quote
my bonnet is loose, and its real noisy... big time...
any ideas on how I can secure it, or at least stop it making a racket each time I hit a bump or turn a corner
PostPosted: Tue May 13, 2003 7:14 am    Post subject: Reply with quote
there should be rubber bumperettes in between the fender and the "bonnet"
3 928s,
kabok
PostPosted: Tue May 13, 2003 7:33 am    Post subject: Reply with quote
Make sure your bonnet is secure at the hinges. If that checks out make sure the latch does not have too much free play. When you push down on the bonnet it should click and stay down. Otherwise adjust the shaft on the latch. The next step will be to look at the rubber between the body and the bonnet. I used foam Strips to stop my rattle.
