Ignition coil
78porsche924
PostPosted: Fri May 09, 2003 8:53 am    Post subject: Ignition coil Reply with quote
Are coils universal to all cars? I am looking at the coil on the top
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=1656&prmenbr=361
and it doesn't say anything about being for a specific car. Would this work in mine. Thanks.
90 944 S2
snailshell trans
Bae turbo kit
to check out my 944 S2 http://www.cardomain.com/member_pages/view_page.pl?page_id=388139
View user's profile Send private message Send e-mail Visit poster's website AIM Address Yahoo Messenger
wdb
PostPosted: Fri May 09, 2003 9:00 am    Post subject: Reply with quote
I think most coils are the same , you could even use a $10 chevy coil .
PostPosted: Fri May 09, 2003 9:02 am    Post subject: Reply with quote
should work fine in your car, but the 78 924 NA is a resistered engine, if I remember correctly, but then again the resister was to stop it from frying points but these cars don't have points so I don't know
3 928s,
78porsche924
PostPosted: Fri May 09, 2003 9:12 am    Post subject: Reply with quote
The one i am looking at comes with a resistor anyway. And i thought that the points had a resistor in them. At least that is what a few people said in a different thread.
I am not in danger of frying something for using this if it is wrong am i?
90 944 S2
snailshell trans
Bae turbo kit
PostPosted: Fri May 09, 2003 9:21 am    Post subject: Reply with quote
if in doubt use the external resister
3 928s,
78porsche924
Ok thanks.
90 944 S2
snailshell trans
Bae turbo kit
bryanc
PostPosted: Fri May 09, 2003 11:32 am    Post subject: Reply with quote
If your car has mechanical points I will defer to the other answers. If you have electronic ignition coils are very specific to the ignition system. The primary resistance, saturation current, inductance, and other specifications mean the correct coil is necessary.
If a coil is specified IN PRINT to be for a specific application you can be reasonably sure the coil will work. Quality on the other hand is open for interpertation.
I'm currently using an Auto Zone $12.00 coil and have had no problems with it although it is a daily driver not a racer.
'84 944
I'd rather have a bottle in front a' me than a frontal lobotomy
Tom Waits
78porsche924
PostPosted: Fri May 09, 2003 12:00 pm    Post subject: Reply with quote
I believe i have electronic. Mine is a Us car and i think they all are electronic. Someone else bought theirs from jeg's. Guess i will be giving them a call tomorrow. I already placed my order.
90 944 S2
snailshell trans
Bae turbo kit
PostPosted: Fri May 09, 2003 11:22 pm    Post subject: Reply with quote
Yeah, not such a big deal if you've got the right resistance et al... I'm using an MSD Blaster 2 coil in the racecar, though I had to muddle around with resistors...
78porsche924
PostPosted: Sat May 10, 2003 3:25 pm    Post subject: Reply with quote
It comes with a balast resistor (.8ohm) that u can use if you want to. What ohm resistors did you use and how?
90 944 S2
snailshell trans
Bae turbo kit
