78porsche924
Joined: 14 Dec 2002 Posts: 1217 Location: Newark, DE(near where DE,MD and PA meets)
Posted: Thu May 08, 2003 10:49 am Post subject: New spark plugs |
I am going to need new spark plugs. I have been told i should probably run hotter plugs because i got a turbo. What would any of you recommend? I plan on getting a msd blaster 2 coil if that makes any difference from jegs. Also what are the specs as to sizes and stuff like that.
Thanks
Bobby _________________ 90 944 S2
snailshell trans
Bae turbo kit
to check out my 944 S2 http://www.cardomain.com/member_pages/view_page.pl?page_id=388139 |
Roger
Posted: Thu May 08, 2003 11:15 am Post subject: |
I ordered some hotter plugs they are Bosch W5DC _________________ 1981 924 NA
78porsche924
Posted: Fri May 09, 2003 8:56 am Post subject: |
Thanks. I am looking for basically the best plugs i can get. I don't mind spending more for them. Are these the best out there? _________________ 90 944 S2
snailshell trans
Bae turbo kit
wdb
Posted: Fri May 09, 2003 9:08 am Post subject: |
| I believe hot plugs are for city driving ,(alot of short trips .) they get hot fast to burn off deposits . if you do mostly highway miles you want the cool plugs . |
78porsche924
Posted: Fri May 09, 2003 9:14 am Post subject: |
O, lizard said it sounded like i needed hotter plugs because my engine to cut out at higher rpms with the pedal down. I know there is something up with the ignition because it got better once i fixed a contact of the ignition wire on my battery. Still not all that great though. _________________ 90 944 S2
snailshell trans
Bae turbo kit
Posted: Fri May 09, 2003 9:17 am Post subject: |
sorry 78porsche924, you miss understood me, I said a hotter spark not spark plug, basically a new ignition coil like MSD blaster 2 ignition coil _________________ 3 928s, |
78porsche924
Posted: Fri May 09, 2003 9:23 am Post subject: |
Oh, sorry man. Good thing u caught this post before i did something stupid. I am going with that coil anyway. I need to replace my spark plugs cause they are kinda old. Are the bosche 4+ platinum really worth the money? Which part number would be best for my car if they are or how do i find out?
thanks
bobby _________________ 90 944 S2
snailshell trans
Bae turbo kit
Roger
Posted: Fri May 09, 2003 9:39 am Post subject: |
They are not the best plugs out there. They are a coper core plug. I am not really a beliver in multiple electrode plugs. I think platinum pugs are better but thats only because they can last longer. More spark more horsepower? More spark better gas millage? I doubt it does much. Once the gas is ignited it is going to burn at the same rate. I have read this before but I may not remember it correctly. Hotter plugs have a longer insulator to withstand higher temps in the combustion chamber. Mostly to keep from burning the plugs under extreme driving conditions. I also doubt that a better coil adds much. The stock coil operates at something like 10,000 volts. I am not really sure about that number, but the point is that once the gas is ignited it still burns at the same rate. If you are going to replace the system upgrading is a good idea, but will it make much difference for average driving conditions? _________________ 1981 924 NA
Posted: Fri May 09, 2003 9:41 am Post subject: |
the bosch platnum +4 are nice plugs but I don't like how the electrode is surrounded by insulation, makes it to prone to high speed glazing, which is a film that conducts electricity, lowering the amount of spark.
speaking of which does anyone have a dual spark setup on there car and does it help? _________________ 3 928s, |
Phogphire1
Joined: 05 Apr 2003 Posts: 293 Location: Portland, OR
Posted: Fri May 09, 2003 9:52 am Post subject: |
I read somewhere that the only perfomance improvment from the +2 or +4 plugs are on the Turbo or Multi-valve cars otherwise you are throwing your $ away and even the platinum is most advantougeus where you have diffcult acess to the plug i.e. some trans mounted V6 engines mainly FWD cars. _________________ Extremism in the defense of liberty is no vice. And moderation in the pursuit of justice is no virtue.
Life, Liberty and the Pursuit of thoose that dare screw with it. |
Posted: Fri May 09, 2003 9:54 am Post subject: |
the hotter spark does make abit of a difference, and on a failing system it makes a big difference _________________ 3 928s, |
78porsche924
Roger
Posted: Fri May 09, 2003 10:29 am Post subject: |
It cant hurt _________________ 1981 924 NA
78porsche924
moone924
Joined: 05 Feb 2003 Posts: 869 Location: Douglas Wyoming
Posted: Fri May 09, 2003 5:10 pm Post subject: |
THis guy www.eurocars.bz once told me platiums are really only good for Turbo cars. He thinks Bosch Supers are the best all around plug. _________________ Ryan Moone
New philosophy : one car project at a time. |
