ltgland
Joined: 02 Nov 2002 Posts: 742 Location: London (that England, Europe for the geographically declined)
Posted: Tue May 13, 2003 7:06 am Post subject: noisy bonnet |
my bonnet is loose, and its real noisy... big time...
any ideas on how I can secure it, or at least stop it making a racket each time I hit a bump or turn a corner |
Posted: Tue May 13, 2003 7:14 am Post subject: |
there should be rubber bumperettes in between the fender and the "bonnet" _________________ 3 928s, |
kabok
Joined: 25 Jan 2003 Posts: 179 Location: Ft. Collins, CO
Posted: Tue May 13, 2003 7:33 am Post subject: |
| Make sure your bonnet is secure at the hinges. If that checks out make sure the latch does not have too much free play. When you push down on the bonnet it should click and stay down. Otherwise adjust the shaft on the latch. The next step will be to look at the rubber between the body and the bonnet. I used foam Strips to stop my rattle. |
