NINEEAGLES
Posted: Sat May 03, 2003 1:29 am Post subject: got a annoying shifter rattle |
| my shifter rattle is really annoying....all speeds unless I put keep my hand on it....is it just the nylon bushing that goes under the shift lever or is it something else?....also does anyone know how to keep the shifter boot down....the clips don't seem to grab and it always pops back up?? |
Posted: Sat May 03, 2003 1:32 am Post subject: |
what year of car, it could be a few different things it could be the bushings under the boot inside the car but on the audi tranny it has some bushings on the tranny that could cause it _________________ 3 928s, |
NINEEAGLES
Posted: Sat May 03, 2003 2:48 am Post subject: |
| Its a '79 924...... |
Posted: Sat May 03, 2003 2:54 am Post subject: |
79 924, should have the snailshell tranny could be the bushings under the boot inside the car or it could be the ball type joint on the torque tube _________________ 3 928s, |
NINEEAGLES
Posted: Sat May 03, 2003 3:31 am Post subject: |
| thanks lizard.....I will have to investigate....I have a new nylon bushing but haven't had a chance to take it apart yet....... |
augidog
Posted: Sat May 03, 2003 12:16 pm Post subject: |
buy a new lever.It really helped mine.The conection wears out the joint .http://www.924board.org/viewtopic.php?t=6790&highlight= _________________ 1978 924 95 mile daily driver.
c4924
Posted: Thu May 08, 2003 1:07 am Post subject: Mine is LOUD, also |
| I ordered and recieved these two little " washer " type pieces. Have'nt figured out what they are, but figure once I crawl under there ; I'll find out. |
Neil924
Posted: Thu May 08, 2003 1:10 am Post subject: |
| HA! Proper thing! |
CMXXXI
Posted: Thu May 08, 2003 4:54 am Post subject: |
| c4924 wrote: | | I ordered and recieved these two little " washer " type pieces. Have'nt figured out what they are, but figure once I crawl under there ; I'll find out. |
Good luck. I think that once you are under there, you'll discover the linkage is about impossible to reach. I couldn't get my hand up in there, much less work with tools up in that abyss. _________________ '79 Eurospec 931 |
Posted: Thu May 08, 2003 5:18 am Post subject: |
| CMXXXI wrote: | | c4924 wrote: | | I ordered and recieved these two little " washer " type pieces. Have'nt figured out what they are, but figure once I crawl under there ; I'll find out. |
Good luck. I think that once you are under there, you'll discover the linkage is about impossible to reach. I couldn't get my hand up in there, much less work with tools up in that abyss. |
what r u talking about on a audi based tranny there is more than enough reomve to access the shifter without dropping tranny, but I am double jointed so eh _________________ 3 928s, |
Alex Roy
Joined: 03 Nov 2002 Posts: 694 Location: Springfield Oregon USA
Posted: Thu May 08, 2003 6:04 am Post subject: |
| the '79 that NINEEAGLES has and the '79/'80 931 that CMXXXI has both have the snail shell trany, which is impossible to get to the linkage without dropping the trany and torque tube.......they are nothing like the audi boxes. |
Posted: Thu May 08, 2003 6:08 am Post subject: |
| Alex Roy wrote: | | the '79 that NINEEAGLES has and the '79/'80 931 that CMXXXI has both have the snail shell trany, which is impossible to get to the linkage without dropping the trany and torque tube.......they are nothing like the audi boxes. |
yes but I was talking of the audi box that c4924 got the washer type busings for, but yah the snailshell there is no way to get your hands up there _________________ 3 928s, |
78porsche924
Joined: 14 Dec 2002 Posts: 1217 Location: Newark, DE(near where DE,MD and PA meets)
Posted: Thu May 08, 2003 7:00 am Post subject: |
| Where would i get those bushings from? Looking down on my shifter from the drivers seat(left hand drive) it looks like something is very loose to the upper right. Is that a replaceable bushing? I want to replace pretty much all of the bushings. |
Posted: Thu May 08, 2003 7:11 am Post subject: |
| 78porsche924 wrote: | | Where would i get those bushings from? Looking down on my shifter from the drivers seat(left hand drive) it looks like something is very loose to the upper right. Is that a replaceable bushing? I want to replace pretty much all of the bushings. |
in a 78 you would have an audi tranny and for that just get a replacement lever from performance products, look under 84 944 if I remember correctly _________________ 3 928s, |
78porsche924
Posted: Thu May 08, 2003 7:14 am Post subject: |
| PO swapped in the snailshell so i have one out of a 79. Sorry, forgot to mention that. |
