Wiring Harness
924ttrouble
PostPosted: Mon Mar 03, 2003 8:13 am    Post subject: Wiring Harness Reply with quote
Is it possible just to remove a section of the wiring harness? Mainly the section that control the head lights and the instrument lights. I traced my problem to that and on the underside of the harness was completed cook. I didn't even notice it until I started messing around with the wiring. Any help out there???
PostPosted: Mon Mar 03, 2003 10:07 am    Post subject: Reply with quote
of course. The different sections are usually taped together, especially under the dash. Just take your time and only remove as much tape as you have to to split the section from other sections it may be taped to.
924ttrouble
PostPosted: Mon Mar 03, 2003 10:45 am    Post subject: Reply with quote
Thanks for the info, are all the section independant of each other?
gohim
PostPosted: Mon Mar 03, 2003 11:24 am    Post subject: Reply with quote
If you are asking if one or more sections of the wiring harness can be removed, and replaced without affecting other sections, yes, as long as you don't knock anything else loose while you are down there.
What year is your are, many of the people on this board probably have extra wiring harness parts in storage that would fit your needs and cost less than you could buy them from Porsche or from a salvage yard.
Personally, I have most of the harness from a 80 931 that was stripped to make a race car.
924ttrouble
PostPosted: Mon Mar 03, 2003 12:18 pm    Post subject: Reply with quote
I have a 1982 The only section that was affected I think is the headlight. I have a new headlight switch, well used headlight switch from the junk yard. I'm in the process of pealing back the wire cover to see what else is affected and so far all I see is 4 wire that have melted together.
Question? Does the fire wall plug come out as one peice or do I have to cut it to remove that section of the harness? If I cut it, is it easy to replace with something?
924ttrouble
PostPosted: Mon Mar 03, 2003 12:21 pm    Post subject: Reply with quote
GOHIM, Do you have that section of the harness that I need and if so are you willing to sell it? You can e-mail at dgander5@aol.com
gohim
PostPosted: Wed Mar 05, 2003 2:06 pm    Post subject: Reply with quote
The headlight swit5ches are not all the same, and neither are the wiring harnesses from different year cars.
Do you have a 82 924 NA?. I can check to see if what I have is compatible. I won't cut open a wiring harness section, you would have to take to whole part as it unplugs.
Zuffen
PostPosted: Thu Mar 06, 2003 1:03 am    Post subject: caution Reply with quote
If I remember right,
If someone added a headlight relay, the 81 and 82 931 don't require one. When you have the relay there it will smoke/melt the switch and the wiring.
Be careful and get the correct wire and relay map for that year, don't trust Haynes or Chiltons, or Porsche on the general info sections.
Bob Dodd - 924turbo@cox.net
924ttrouble
PostPosted: Thu Mar 06, 2003 11:04 am    Post subject: Reply with quote
To late! I already cut open that part of the wiring harness to see how many wires were burnt. I didn't remove it from the relay board as of yet. The thing is hard to get to. I don't know what a NA is? I just know this is an 82 turbo.
gohim
PostPosted: Thu Mar 06, 2003 1:25 pm    Post subject: Reply with quote
NA is normally aspired (NOT TURBO).
I will check and see if I have have you need.
PostPosted: Thu Mar 06, 2003 3:54 pm    Post subject: Reply with quote
I thought NA was for north american as in not a euro spec high cp motored 924...Zuffen is that you there in the avitar..right on.
Zuffen
PostPosted: Fri Mar 07, 2003 1:55 am    Post subject: Reply with quote
hey joe, check this thread out
http://www.924board.org/viewtopic.php?t=6197
gohim
PostPosted: Fri Mar 07, 2003 8:15 am    Post subject: Reply with quote
I went out to the garage and sorted out the wiring harness from the Turbo that I had sitting in a box.
Sorry, the headlight switch is there, but the connectors and associated wiring have been chopped off where they merge into the main portion of the harness. The plug that connects to the fuse block is still there.
924ttrouble
PostPosted: Fri Mar 07, 2003 11:09 am    Post subject: Reply with quote
Thanks anyway, I'm going to see if I can peice it out tonight and if not I know where their is a 944 1984 in the junk yard, I'll see if i can get that peice of the wiring harness.Hopefully it the same thing. Wish me luck.
924ttrouble
PostPosted: Fri Mar 21, 2003 2:36 pm    Post subject: Reply with quote
Update to wiring harness, all wires are sliced in Except one red/yellow that I'm still trying to chase out from under the dash. Still have about 7 wires to resolder in to the light switch but not until I trace out the 1 wire.
