Tornadoair...Hmm
Levans
PostPosted: Fri Dec 13, 2002 1:47 am    Post subject: Tornadoair...Hmm Reply with quote
I know this "invention" has been arround for years but has anyone actually tried this on a 924?
Are they just a money making item?
whats your guys opinions?
http://www.tornadoair.com/what_is_it_.htm
78 Dark met Green "THE 924"
924 turbo
PostPosted: Fri Dec 13, 2002 7:44 am    Post subject: Reply with quote
I remember reading somewhere that a car magazine used one on a long-term test vehicle, and it didn't do anything.
Jon Furst
PostPosted: Fri Dec 13, 2002 9:30 am    Post subject: Reply with quote
yea it doesnt work on our system
I suppose you could get dual carbs then
design a cold air intake system and have
the air swirly thing in there somewhere.
btw the tornado is a haox for a porsche
to see gains .
CBass
PostPosted: Mon Dec 16, 2002 3:42 am    Post subject: Reply with quote
Yeah, I toyed with the notion of building one out of sheet metal. Their "precision machined fins" are a couple pieces of sheet steel, fitted in a round section of sheet. It's not even welded
AFBCamaro
PostPosted: Mon Dec 16, 2002 6:14 am    Post subject: Reply with quote
It doesnt work on ANY system! They will give you a 1-3 hp difference on factory badly designed intake systems. Very badly designed ones at that!!!
K&n spent money designing a filter that straightens intake flow. And here this thing wants to swirl the air. Swirling the air brings better atomization(at high pressure drop, only found near the port of the head) but by the time it (swirled air) enters the head the pressure drop negates this swirl. As the engine takes in air through the valves the pressure drop will "straighten" the air out.
Gm toyed with this swirling technicque on some heads(the only way it works at the port). The head ports are called swirl port heads. They overdid it and flow was restricted to much. They suck for power. If its done midly like on vortec heads you get less detonation prone heads, and slightly better economy with a "little extra power".
1982 Porsche 924 in mild restoration process.
1991 Chevy Camaro RS "Freigh Train"
PostPosted: Mon Dec 16, 2002 8:30 am    Post subject: Reply with quote
the whole atomisation thing that these BS devices talk about is designed to con those people who still think their car has a carb on it.
When the already atomised spray from your injectors gets hit by a stream of air travelling at close to the speed of sound you can be sure that any fuel that isn't already is going to get the life atomised out of it. Touchy, feely swirly air has nothing to do with it.
1982Porsche924
PostPosted: Mon Dec 16, 2002 3:21 pm    Post subject: Reply with quote
"What exactly is a TORNADO? It's an air twister with 10 years of research and development behind it."
10 years of research?!?! more like 10 years figuring out in how to sell the piece of crap. It's funny to see how ricers list this product as an "engine mod" though.
1979 Porsche 924 "S"
Engine: Euro pistons, Light Flywheel, Weber TB, Bursch Header, Cam Wheel
Suspension: Front coil-overs, adj sways, Solid bush. Thicker tors. bars, 5-bolt, BBS rims
Body: Fiberglass widebody kit, 931 Nose
AFBCamaro
PostPosted: Tue Dec 17, 2002 1:58 am    Post subject: Reply with quote
Touchy swirly air!! I LIKE IT!!
PostPosted: Sat Dec 28, 2002 5:58 am    Post subject: Reply with quote
This is a con thlse things are spendy 2..Youd be better off assuring a cold air system by making your own.
