Temperature Switch 047 131 851 D Purpose?
Legitimate Salvage
PostPosted: Tue Dec 30, 2025 1:41 am    Post subject: Temperature Switch 047 131 851 D Purpose? Reply with quote
1979 924 2.0 NA
Curious what the purpose of the above switch is. It screws in to the hard coolant line that runs behind the block at the firewall (just under the ignition coil). I removed my ignition distributor yesterday and found that the wires to this switch were replaced/spliced... poorly.
1979 924 NA - AKA the Mid-life Crisis
2012 Audi A3 - The Daily
1991 MB 300D
1984 MB 300D
1966 Mustang I6
Raize
PostPosted: Tue Dec 30, 2025 8:40 am    Post subject: Reply with quote
Hot start solenoid switch, normally open, closed above 45C.
Activates the hot start solenoid when cranking to drop control pressure to zero and break the vapour lock in the injector lines.
Rarely work in my experience.
