Fuel line in to distributor not sealing
bureau13
PostPosted: Mon Jan 13, 2025 7:51 am    Post subject: Fuel line in to distributor not sealing Reply with quote
I made the mistake of disconnecting the fuel in line at the distributor banjo bolt, thinking I had the adapters to connect to a fuel pressure gauge, but I did not. Now I keep seeping fuel even though I've tried several sets of copper washers. I think that's an M12 fitting. Anyone have the specs on the required washers? Maybe mine are too thin.
It's a 1982 Turbo, although I suspect they are all the same in this area.
1986.5 Silver 928S
2008 Volvo XC90 (Daily)
Past lives (I miss them all):
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen)
Raize
PostPosted: Mon Jan 13, 2025 7:55 pm    Post subject: Reply with quote
I ended up using Dowty washers on mine. Must have tried to get it to seal with the copper ones at least a dozen times with no luck.
PostPosted: Mon Jan 13, 2025 8:06 pm    Post subject: Reply with quote
I couldn't get the FD stop leaking with my generic copper washers. Bought them from Porsche and it didn't leak a drop. The dimensions and material differed a bit, obviously enough:)
PostPosted: Mon Jan 13, 2025 8:34 pm    Post subject: Reply with quote
Yeah the copper washer used for fuel sealing have a soft outer layer that does the sealing.
You can id them by their edge bevel/radius. The regular ones have sharp edges.
PostPosted: Tue Jan 14, 2025 12:36 am    Post subject: Reply with quote
You could try taking out the washer and then heating it very hot with a propane torch. It would take out any work hardening, ie the copper would be softer after cooling.
Mike
bureau13
PostPosted: Tue Jan 14, 2025 7:01 am    Post subject: Reply with quote
Thanks for the info. I ordered a new set that claims to specifically be for this purpose, so we will see it that works.
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
!tom
PostPosted: Fri Jan 17, 2025 5:22 am    Post subject: Reply with quote
I think it's important to quench the heated copper to anneal it so that it is soft enough to seal.
Heat washer hot with torch, then dunk in water. Should be able to re-use after that process.
78 924 NA
5-lug
bureau13
PostPosted: Sun Jan 19, 2025 1:03 am    Post subject: Reply with quote
For what it's worth, I just bought a new pack of washers and made sure they specifically claimed to be crush washers for sealing. I don't know if the other ones were NOT intended for that, were just crap, or I got lucky, but the new set worked perfectly first try.
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
