Caliper Clearance
Raize
PostPosted: Mon Oct 28, 2024 10:14 pm    Post subject: Caliper Clearance Reply with quote
Is this too close to the rim?
I also only have 4 turns of engagement for the wheel bolts, guess longer ones are needed.
PostPosted: Tue Oct 29, 2024 11:24 pm    Post subject: Reply with quote
Two possible. First, if you use stick on wheel balance weights you might have a problem with rubbing. Secondly, are your brake discs entirely on the rotor or off the edge, If so you will have the rotor dragging on the over hanging edge of the puck. The overhanging pad can be cut off with a hack saw. I had both of these on my race car.
Mike
safe
PostPosted: Thu Oct 31, 2024 12:11 am    Post subject: Reply with quote
Yes, get longer bolts!
You don't need much clearance, 2-3 mm should be enough.
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
Raize
PostPosted: Mon Nov 04, 2024 3:38 am    Post subject: Reply with quote
It's only 1mm gap right now...
I think probably best option is to use a wheel spacer since new longer bolts are needed anyway. Plenty of room for spaced out rear wheels on the 924, arguably worth it just for the better look.
That will increase the clearance by moving along the "taper" of the wheel barrel and also provide a space in which the stick-on wheel weights can be safely placed beyond the caliper.
I have no pad overhang (in fact about 3mm unused disc) because I had to move the caliper in until the carrier slot was almost touching the disc to maximise the wheel barrel clearance. In the end I am using very tiny pads (31mm high) on a disc with 40mm of possible surface so it's not really a problem.
