Raize
Posted: Sun Apr 14, 2024 3:09 am Post subject: Ignition Timing Map |
Anyone have any comments on whether this would be a good ignition timing map for a N/A 2.0 with boost? Assume AFRs are done properly, Euro compression ratio, and intercooling. |
Raize
Posted: Sun Apr 14, 2024 5:06 am Post subject: |
UK 99 RON which would be equivalent to USA 95 |
Posted: Sun Apr 14, 2024 9:38 pm Post subject: |
US-spec 931, but here's my ignition map (from the Megasquirts experts thread):
I'm not sure why you would want such high advance of 52 on high vacuum/rpms?
The low RPM values around 6-8 degrees control the idle speed, with the very high advance at 600rpm to keep the car from stalling.
I have actually massaged things a bit since the above was posted, but this should give a decent baseline... there were a few discontinuities that needed to be sorted, mainly I think it was the progression from the 45 to the 80kPa line, and from 1500-2000rpm - that was a bit of an abrupt jump, so driveability around 2000rpm and light throttle in stop-and-go traffic got pretty jumpy and unpleasant. _________________ Vaughan Scott
Posted: Sun Apr 14, 2024 9:52 pm Post subject: |
Update - posted my latest maps, so linking from the Rennlist thread... tuned for US 93 octane gas (though far from the limit, I have a WBO2 sensor but no knock sensor and haven't run on a dyno, just street tuning).
Boost is set at 14psi...
You can see the difference in the ignition map for smoothing vs. the previous one. Much happier and smoother in stop-and-go traffic at 2000rpm.
Raize
Posted: Sat Apr 20, 2024 9:53 pm Post subject: |
Thanks for the data.
Couple questions:
1. You have all your timing in at 2500 RPM from 85 KPa upwards. I was going with the stock Porsche ignition curve being all-in at 3000-4000rpm, are they too conservative?
2. What's the purpose of the retarded timing below 3500 RPM at high vacuum (55 KPa and upwards)? I understand the 6 and 8 part is for idle control, is the 16-25-30 just smoothing?
3. Is it generally knock-limited or MBT-limited with the gas you run? |
Posted: Sun Apr 21, 2024 9:24 am Post subject: |
| Raize wrote: | Thanks for the data.
Couple questions:
1. You have all your timing in at 2500 RPM from 85 KPa upwards. I was going with the stock Porsche ignition curve being all-in at 3000-4000rpm, are they too conservative? |
I'd say so. But I'm tuned for much better octane too. Plus we have better controls, more precise, more complex and reliable, etc.
| Raize wrote: |
2. What's the purpose of the retarded timing below 3500 RPM at high vacuum (55 KPa and upwards)? I understand the 6 and 8 part is for idle control, is the 16-25-30 just smoothing? |
Exactly.
| Raize wrote: |
I'm not knock limited or anything of the sort; this is a conservative tune that doesn't run to the limit, since I haven't dynoed or run any knock detection. _________________ Vaughan Scott
Raize
Posted: Sun Apr 21, 2024 7:48 pm Post subject: |
| 924RACR wrote: |
I'm not knock limited or anything of the sort; this is a conservative tune that doesn't run to the limit, since I haven't dynoed or run any knock detection. |
That's good to know. The only data I have for my car is that on 99 octane (USA 93) it starts to lightly knock at 36 degrees timing and on 97 octane (USA 91) it starts to lightly knock around 32 degrees timing, at 120 KPa.
The NA obviously has higher compression than the 931 so would need less timing because of that. But equally, it has a worse combustion chamber shape that requires more timing than the 931.
Also not sure if there's a pressure level where the engine will just knock because of the high-ish 9.3:1 compression ratio and no amount of ignition timing retard will change it, and what that pressure would be for an intercooled NA running premium gas. |
Posted: Mon Apr 22, 2024 9:11 pm Post subject: |
I'm surprised that your motor will knock that easily. Doesn't seem right, perhaps it wants some clean-up in the combustion chambers?
We also have an NA racecar, with a basically stock NA head on it, used to run 9.5:1 compression with stock cam, 93 US octane, and no problem running up to 42 degrees of compression (max power) as long as the fueling's good.
So on that latter point, how is your fueling, do you have a wideband? _________________ Vaughan Scott
Posted: Mon Apr 22, 2024 11:38 pm Post subject: |
What Vaughan said above. I had the same thing (9.5:1 with 93 Octane) at 41 degrees and ran a CO of 12.6-13.1 with no knock. Now we both have 11:1 compression engines (I'm running 100 Octane) and a bit less advance with no knock. _________________ 1979 924 NA race car H-Prod SCCA
Raize
Posted: Tue Apr 23, 2024 5:50 am Post subject: |
I have 14-14.5 AFR so it's not ideal.
Will be reducing this to around 12 soon. Should be able to pick up some more timing with that change. |
Posted: Tue Apr 23, 2024 7:13 am Post subject: |
12 is too rich unless its turbocharged... _________________ 1979 924 NA race car H-Prod SCCA
Posted: Tue Apr 23, 2024 5:20 pm Post subject: |
| Raize wrote: | I have 14-14.5 AFR so it's not ideal.
12,7 at n/a for max power and then lower as boost goes up,how much depending if you use a supercharger or turbocharger.
One thing here, never use any ones ignition map other than for reference to build a rough map, things can be a bit different between setups for a multitude of reasons, start a bit conservative and work yourself up. _________________ 1980 924 Turbo
Raize
Posted: Sat Apr 27, 2024 9:39 pm Post subject: |
| Cedric wrote: | | Raize wrote: | I have 14-14.5 AFR so it's not ideal.
One thing here, never use any ones ignition map other than for reference to build a rough map, things can be a bit different between setups for a multitude of reasons, start a bit conservative and work yourself up. |
I don't have that fine control over the fuelling, with K-jetronic I can basically have two settings with my vacuum-diaphgram WUR - one for vacuum and one for positive pressure.
In theory you could make it get richer gradually as boost increases by using stronger springs in the WUR. I'm using a supercharger so I'm not really in a "partial boost" situation often like with a turbo needing to spool up. |
Raize
Posted: Sat Apr 27, 2024 11:08 pm Post subject: |
Just did my K-Jetronic Quantity Testing on the new Volvo metering head and I have the normal slight variances...
3% at maximum flow
6% at half way up
6% near idle
Cylinder 4 is the hot one on these engines right? I will put my highest flowing injector to it if I can. |
