andrew924
Joined: 01 Nov 2023 Posts: 2 Location: Auckland, New Zealand
Posted: Mon Feb 26, 2024 5:30 pm Post subject: Help - Headlights stay on full and Horn goes non stop |
Hi guys
Pulling my hair out, just installed new turn signal switch and windshield wiper switch.
I have tried to search online but given up.
Then the wipers would only run on two settings, then burst into life and couldn't stop them.
Disconnected the wiring loom reconnected and they now work perfectly.
However the headlights now stay on all the time even when no key in the ignition, found this out with a flat battery as the car was outside when i reconnected the battery
Also the horn stays on all the time, if i unscrew the screws that hold the switch gear together on the steering column it stops......... but the horn button does not work.
Probably a real simple answer but i have always struggled with electrical matters
ANY help or advise welcome. |
Posted: Tue Feb 27, 2024 5:53 am Post subject: |
Got the right stalks? Most probably all problems are related to those stalks. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
andrew924
Posted: Tue Feb 27, 2024 6:05 am Post subject: |
yes i understand they are correct, i have had a look and all the wires go to the correct pins etc  |
Rewaaj
Joined: 15 Feb 2023 Posts: 2 Location: usa, wa, seattle
Posted: Mon May 20, 2024 4:33 pm Post subject: |
Hey there, revving up the convo with my two cents! Checking out your ride, I gotta say, that horn is slick! Nothing like a blast from a badass horn to announce your presence on the road, am I right?
As for the topic at hand, I'm all for upgrading the horn game. It's not just about making noise; it's about making a statement! A horn with personality adds that extra oomph to your ride, like the cherry on top of a sweet ride sundae. Plus, it's a safety thing too – letting folks know you're coming through.
So, what's the vibe from the crew? Anyone else jazzed about jazzing up their horns? Let's hear your honkin' good ideas! |
