Injector plug size? turbo head w/ carbs
jimhuiz
PostPosted: Tue Dec 19, 2023 2:01 am    Post subject: Injector plug size? turbo head w/ carbs Reply with quote
I'm refreshing a 924 Michael Mount race engine and want to replace the injector plugs which are large Allen head bolts/plugs as they're quite corroded/ugly. (it runs 50 DCO carbs)
Can anyone point me to the proper size/thread/length?
TIA!
Jim H.
PostPosted: Tue Dec 19, 2023 10:29 pm    Post subject: Reply with quote
When I was modifying heads I fund some I think from Belmetric Bolt. As I recall either 21 or 22mm. Measure with calipers, It is a metric pipe plug. PM sent
Mike
PostPosted: Thu Dec 21, 2023 11:54 pm    Post subject: Reply with quote
Update, 22mm from McMaster Carr get the ones with a sunken hex heads as the flanged one won't seal.
Mike
jimhuiz
PostPosted: Fri Dec 22, 2023 6:34 am    Post subject: Reply with quote
Thanks!
PostPosted: Fri Dec 29, 2023 10:10 pm    Post subject: Reply with quote
Hmmm, so not too sure about this. I just chased the threads in one of my heads with an M24 x 1.5 tap.
Unless the 22mm pipe thread matches up with that?
