What master cylinder for 5 lug conversion
SorenPeterson
PostPosted: Tue Dec 12, 2023 12:36 am    Post subject: What master cylinder for 5 lug conversion Reply with quote
Ive just bought the complete suspention from a 83 944 but i was not able to snag the master
My 1979 924 has the diagonal system with the small master
Would i be able to just slap the brakes on with the current master and plumbing or is a 944 master a must?
1979 924 n/a, G31, LQ4 swap, 5 lug.
$500 ford ranger 5 speed
!tom
PostPosted: Tue Dec 12, 2023 3:12 am    Post subject: Reply with quote
Yes, you can keep your brake line routing, as the routing requirements follow the master cylinder type.
Just slap the brakes on, and you'll be fine. I'm still running the original master in mine.
78 924 NA
5-lug
PostPosted: Tue Dec 12, 2023 10:13 am    Post subject: Reply with quote
Agree. If you use the 944 master and booster it requires rerouting of all brake lines and then the larger booster interferes with the throttle cable routing.
Mike
PostPosted: Wed Dec 13, 2023 3:21 am    Post subject: Reply with quote
My '79 NA came with five lug, four wheel discs and had the small brake booster. Works just fine on the race track.
