chuck21401
Posted: Mon Sep 25, 2023 2:52 am Post subject: Larger (or additional cooler) oil cooler options for the 931 |
Anyone running a larger oil cooler or multiple oil coolers? I've turned up the boost on my car...wondering if additional oil cooling would be helpful.
Looking through old threads, someone mentioned running two stock coolers (93120705101) in series (I'd like to see how those are mounted), someone else suggested adding a larger oil cooler in place of the stock cooler (any recommendations)? My washer bottle was leaking so I've already removed that...so more room for a larger cooler if needed in the stock location. I'm aware that the 924 Carerra gt and GTS moved the cooler up front, better air flow maybe?
What size are the fittings on the stock oil lines/cooler? M22? I'm not seeing any sources for metric lines, looks like I'd have to convert to AN...AN12?
(pic borrowed from ancient thread on Pelican parts)
Source for these pics: https://canepa.com/photo-gallery/1981-porsche-924-carrera-gts-club-sport6648/
Posted: Mon Sep 25, 2023 3:34 am Post subject: |
If you dont track it i would not bother changing it. To get more space for the IC end tank and some additional cooling area i had to swap my original one for a narrower setrab with Banjo connectors. A hydraulic hose shop cut of the old lines and pressed on new teflon steel braided ones for more bendability.
I dont know if its enough, i have some ducting around it aswell. The future will tell
 _________________ 1980 924 Turbo
chuck21401
Posted: Mon Sep 25, 2023 5:07 am Post subject: |
| Cedric wrote: | | If you dont track it i would not bother changing it. |
Yeah, I read comments like that as well in old threads, that the stock cooler is sufficient for the street. With an oil cooled turbo...running higher boost...seems like more cooling would be helpful?
I have no data (yet). Might need to add an oil temp gauge at least temporarily. I'd be curious to see the oil temp after a boost run, then stopped at a stoplight.
| Quote: | To get more space for the IC end tank and some additional cooling area i had to swap my original one for a narrower setrab with Banjo connectors. A hydraulic hose shop cut of the old lines and pressed on new teflon steel braided ones for more bendability.
Thanks for posting that picture. Good idea with the vibration damping mounts. _________________ 1981 Porsche 931 w/S1 engine & euro g31 transaxle. Water-cooled intercooler |
Posted: Mon Sep 25, 2023 5:57 am Post subject: |
Step one get a oil temp sensor and guage i drilled my oil plug and put the sensor there, quick and easy. its not easy to get up to high oil temps on the road, even if you hammer it, i don't live on the hottest place on earth though  _________________ 1980 924 Turbo
Joined: 29 Jul 2001 Posts: 9101 Location: Royal Oak, MI, USA
Posted: Mon Sep 25, 2023 8:44 pm Post subject: |
It seems to me that the stock design of oil manifold/thermostat and pipes out to the cooler is very space-efficient, I'd be inclined to keep that.
But as noted replacing the hose portion would be wise... maybe just in the process have a different non-metric end crimped on, converting to AN for the widest options?
Otherwise, I'm pretty sure Pegasus has the necessary metric adapters... but they're very expensive.
All assuming you need more cooling, as noted. I've found mine is fine with oil pressure (indirectly reading the temp) running VR1 20W50, in ambients up to 90F in traffic... so not boosting, but massively heat soaking. Note that I'm running 14psi and a 951 IC.
So I have no plans for an oil cooler upgrade for this car. _________________ Vaughan Scott
Posted: Wed Sep 27, 2023 5:35 am Post subject: |
No issues with stock oil cooler on my well modified, higher boosted motor. It is running an ally 944 turbo +50% sized coolant radiator. Runs very cool. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
