stan_5150
Posted: Thu Aug 31, 2023 11:56 am Post subject: 1978 NA Steering Rack removal |
I'm in the process of getting to my leaking oil pan from underneath and I’m looking for some guidance on how to remove the steering gear from the lower steering column. I’ve removed the nut and bolt, and sprayed the pinion with some penetrating oil. If anyone has some insight I’m all ears. Thanks I’m advance. _________________ 1978 924 N/A |
Beartooth
Posted: Thu Aug 31, 2023 3:04 pm Post subject: |
Mine was sticky: I think I used a hammer and punch to drive against the underside of the pinion - with the rack still in initially, then once I broke it free I undid all but one bolt (on the side opposite the steering shaft) and tapped it the rest of the way off. You can't get a very direct angle, but if you turn it back and forth so you're driving at different sides, that should help. _________________ 1980 931 diamond in the rough |
Mclaren924
Joined: 13 Oct 2021 Posts: 271 Location: Oceanside CA
Posted: Thu Aug 31, 2023 3:37 pm Post subject: |
I use a chain of socket extensions and a hammer to hit the rack from above, just be wise to where you place the impact. _________________ 1980 931 "Salt" Bucket wannabe racer (Dreaming)
safe
Posted: Fri Sep 01, 2023 1:18 am Post subject: |
Do you need to remove it from the steering rack?
I can't remember if I did or I got the pan out without it. _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe |
