Noud
Posted: Mon Jun 17, 2024 7:59 pm Post subject: Alternator not getting 12V |
Hi, I have a 1982 924 that has a weird issue where the alternator won't charge unless I directly connect 12V to the alternators D+. The voltage regulator and ground strap have already been replaced. Does anyone know where the wire that connects to this D+ goes to or why it doesn't get power?
Thx!
Noud |
Joined: 29 Jul 2001 Posts: 9069 Location: Royal Oak, MI, USA
Posted: Mon Jun 17, 2024 9:28 pm Post subject: |
Going from memory, there should be a circuit through the battery warning light in the dash, the combo gauge cluster, which makes the connection to start charging. Is your dash light bulb out/broken or disconnected? _________________ Vaughan Scott
Noud
Posted: Mon Jun 17, 2024 9:31 pm Post subject: |
| 924RACR wrote: | | Going from memory, there should be a circuit through the battery warning light in the dash, the combo gauge cluster, which makes the connection to start charging. Is your dash light bulb out/broken or disconnected? |
That's what I thought as well so I tested the light and it works but somehow doesn't turn on when I turn the ignition on. |
daniel
Joined: 18 Jun 2009 Posts: 686 Location: Sydney, Australia
Posted: Tue Jun 18, 2024 9:13 am Post subject: |
Rev the engine to 4000rpm, if the regulator is faulty the alternator should charge.
Another thing to consider: I recently chassed down a voltage drop issue in my car that turned out to be the wire from the ignition barrel to the positive side of the coil. It looked fine, tested fine but dropped 2 volts! _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
