BWW
Posted: Fri Aug 26, 2022 10:43 am Post subject: Engine skipping and stalling on acceleration |
I set my timing today using Smoothie's very helpful guide (https://www.924board.org/viewtopic.php?t=18355). But when I open the throttle, the engine, skips, sputters, dies, etc. I know there are many possible causes for this, but is there somewhere in particular I should start? Vacuum leaks? Air-fuel mixture? Thanks! _________________ Brent
'81 931 project car |
Mike9311
Posted: Fri Aug 26, 2022 11:44 pm Post subject: |
vacuum leaks are easy to check so if it idles, just spray brake clean around suspected areas with care. If idle changes due to spray that is you leak. _________________ 1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
BWW
Posted: Sat Aug 27, 2022 2:47 am Post subject: |
Good advice. Thanks, Mike. I will give this a try. I should also mention that there's a clinking/pinging sound coming from the throttle body (I think) when I give it gas. This might be relevant? The video shows what I'm talking about. Thanks again!
https://isu.box.com/s/21ewd0zweqvsd1jf5zjfzs95ug0bd4xo _________________ Brent
BWW
Posted: Tue Aug 30, 2022 7:19 am Post subject: |
I'm following up on this on the off chance that it's useful to someone down the line. I tracked the source of the sound to somewhere in the CIS/k jetronic system. I'm thinking a rebuild might be necessary. _________________ Brent
