DITC pressure line banjo bolt specs
Eliza
PostPosted: Tue Apr 19, 2022 2:52 pm    Post subject: DITC pressure line banjo bolt specs Reply with quote
Hi all!
Is anyone with a series 2 turbo able to measure the banjo bolt that connects the pressure sensing line to the DITC? Overall length and thread length would be great.
I am planning to use a double banjo and additional nipple to connect my boost gauge control line directly at the DITC. Teeing into the pressure line ( 40-year old rubber ) seems a risk I'd rather not take.
Thanks in advance!
Eliza
1985 924 NA RoW
1981 931 S2 RoW
kondzi
PostPosted: Tue Apr 19, 2022 6:06 pm    Post subject: Reply with quote
I'll check, should have my DITC somewhere on shelf in the garage.
Konrad
'89 951 US
'81 931 RoW (TBD)
Eliza
PostPosted: Tue Apr 19, 2022 9:29 pm    Post subject: Reply with quote
Thanks a bunch, Konrad!
1985 924 NA RoW
1981 931 S2 RoW
PostPosted: Tue Apr 19, 2022 11:07 pm    Post subject: Reply with quote
The length is around 17mm long, and thread about 9mm
kondzi
PostPosted: Wed Apr 20, 2022 4:02 am    Post subject: Reply with quote
Bolt is OD 8mm / ID 4mm with 8x1mm thread.
Bolt lenght (without 12mm wrench 6-side head) 17mm (21mm with head).
Bolt thread lenght ~9.8mm
Banjo connector ID 8.1mm
Banjo connector height 8.2mm
Banjo connector inlet ID 3mm
Banjo connector inlet smaller OD 4.5mm / bigger OD 5.5mm
Inlet length (for pipe) 15mm
HTH
Konrad
'89 951 US
'81 931 RoW (TBD)
Eliza
PostPosted: Wed Apr 20, 2022 2:04 pm    Post subject: Reply with quote
Thanks for this!
You guys rock.
Eliza
1985 924 NA RoW
1981 931 S2 RoW
kondzi
PostPosted: Wed Apr 20, 2022 10:58 pm    Post subject: Reply with quote
Eliza wrote:
Thanks for this!
You guys rock.
Eliza
You're just extremely lucky, that my DITC failed and I removed it in favour of MegaSquirt and did not throw it to the bin
Good luck
Konrad
'89 951 US
'81 931 RoW (TBD)
Eliza
PostPosted: Wed Apr 20, 2022 11:40 pm    Post subject: Reply with quote
If at any point you're looking to sell the DITC, do let me know.
I'd love to have a spare, just because and it may be repairable
Thanks again,
Eliza
1985 924 NA RoW
1981 931 S2 RoW
kondzi
PostPosted: Thu Apr 21, 2022 5:13 am    Post subject: Reply with quote
Well in mine it seems DITC alone is fine, but the sensor failed... Or started failing when heating up. Repeatedly. So in the end failed.
Konrad
'89 951 US
'81 931 RoW (TBD)
Eliza
PostPosted: Thu Apr 21, 2022 2:07 pm    Post subject: Reply with quote
Oh nice So, should you want to sell it, drop me a message and let me know what you'd like to have for it.
I believe that the only parts that ever break are the ones you have no replacement for. So I already have a collection of "insurance" spares, and I'd love to add the DITC
Eliza
1985 924 NA RoW
1981 931 S2 RoW
