Skid plate removal question
sbromley
PostPosted: Fri Oct 15, 2021 4:24 am    Post subject: Skid plate removal question Reply with quote
I have an '82 n/a 924 as my first project car! I'm really enjoying it so far, but finding I have a lot to learn.
I'm currently trying to remove the alternator to have it tested, so I need to get underneath it to remove the bolts holding it to the block.
There is a skid plate in place, which I've been trying to remove for a while now. I removed 4 10mm bolts. Two at the rear of the plate, and two on the sides by the wheel wells. As far as I've found those are the expected bolts. There are two more bolts at the front of the plate. These bolts have Phillips heads, a washer, and the plate is folded over the washer. These bolts spin freely, loose enough to twist with my hand, however, they don't back out. Even after unfolding the plate, so the washer would clear it, the bolts won't come out.
Hoping there is a simple solution to this, that I just haven't found yet. Any advice is appreciated.
https://photos.app.goo.gl/EcSPiD9F9EBQmYMKA
1982 924 2.0 n/a
chuck21401
PostPosted: Fri Oct 15, 2021 9:16 am    Post subject: Re: Skid plate removal question Reply with quote
It’s been awhile but it seems like there is a captive nut behind there. The nut is held in place by a slotted bracket of some kind. I think I was able to get a small screwdriver in there to hold the nut and use a larger one to unscrew it.
But I had this issue without the tray in place.
scm924s
PostPosted: Fri Oct 15, 2021 6:43 pm    Post subject: Reply with quote
The captive nut cage rusts allowing the nut to rotate freely, try and stop the nut rotating and if the screw doesn't come out, drill it out and use some plastic push fixings.
1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold
