1978 Fuel Pump Saga - continued
stan_5150
PostPosted: Wed Sep 08, 2021 1:29 am    Post subject: 1978 Fuel Pump Saga - continued Reply with quote
New fuel pump has been installed and it had been leak checked. Went to try to start it and lo and behold I got it to fire for a brief second and then it stopped....ok no big deal, it's a bit more than last time.
So I go to try again, keeps turning and then I notice a hot smell so I immediately stop and check around. Nothing obvious in the engine bay so I disconnect the battery to make sure there isn't any current being pulled through the car.
I trace back to the fuel pump and I notice a couple of drops of fuel on the banjo fitting. Not good. I suspect that the pump is indeed moving fuel but I still have a leak issue at that spot. Anyone have any suggestions for this newbie?
Thanks in advance.
1978 924 N/A
MikeJinCO
PostPosted: Wed Sep 08, 2021 3:09 am    Post subject: Reply with quote
Find some new copper crush washers. The crush washers work harden when the banjo bolt is tightened, so won't always reseal. Supposedly they can be stress relieved if heated with a propane torch, but it didn't seem to work for me. The local hardware might have some that are close enough if not McMaster Carr.com should have metric ones.
Mike
'67 MG Midget Dp
stan_5150
PostPosted: Wed Sep 08, 2021 3:38 am    Post subject: Reply with quote
A gent from the FB groups suggested that I cut the crimp off, refit/replace the banjo etc. I'm considering replacing the accumulator hose as well. I need to see exactly where the leak(s) are coming from before I further action. I had replaced with new coper washers above an below the banjo fitting but may try to replace those at first.
1978 924 N/A
