stan_5150
Posted: Wed Sep 08, 2021 1:29 am Post subject: 1978 Fuel Pump Saga - continued |
New fuel pump has been installed and it had been leak checked. Went to try to start it and lo and behold I got it to fire for a brief second and then it stopped....ok no big deal, it's a bit more than last time.
So I go to try again, keeps turning and then I notice a hot smell so I immediately stop and check around. Nothing obvious in the engine bay so I disconnect the battery to make sure there isn't any current being pulled through the car.
I trace back to the fuel pump and I notice a couple of drops of fuel on the banjo fitting. Not good. I suspect that the pump is indeed moving fuel but I still have a leak issue at that spot. Anyone have any suggestions for this newbie?
Thanks in advance. _________________ 1978 924 N/A |
MikeJinCO
Posted: Wed Sep 08, 2021 3:09 am Post subject: |
Find some new copper crush washers. The crush washers work harden when the banjo bolt is tightened, so won't always reseal. Supposedly they can be stress relieved if heated with a propane torch, but it didn't seem to work for me. The local hardware might have some that are close enough if not McMaster Carr.com should have metric ones. _________________ Mike
'67 MG Midget Dp
stan_5150
Posted: Wed Sep 08, 2021 3:38 am Post subject: |
A gent from the FB groups suggested that I cut the crimp off, refit/replace the banjo etc. I'm considering replacing the accumulator hose as well. I need to see exactly where the leak(s) are coming from before I further action. I had replaced with new coper washers above an below the banjo fitting but may try to replace those at first. _________________ 1978 924 N/A |
