gml
Joined: 04 Mar 2021 Posts: 133 Location: Ontario Canada
Posted: Thu Jul 08, 2021 3:08 pm Post subject: Oily spark plugs and weak engine — where do I go from here |
Hey all, after replacing the fuel filter and vacuum lines my 924 NA has been starting and running sort of okay, but it idles erratically at first, and when I take it out around the block it accelerates really poorly (although it eventually idles fine). As per the previous recommendations I am going to do a fuel pressure test.
However — I recalled that I encountered oil on the spark plugs when I replaced the old ones, and realized that oil in the combustion chamber could also cause poor engine performance.
Does anyone know for the 924 what oily spark plugs usually indicate? What's the best way to diagnose/test it? _________________ George
1982 924 NA 5-speed |
gml
Posted: Thu Jul 08, 2021 4:17 pm Post subject: |
Just in case it helps diagnose something I have photos of the spark plugs. (Numbered sequentially 1 through 4 from front bumper to rear)
1 and 3 both have a slick oily gunk on the electrode where 2 and 4 do not. All of them had a bit of oil on them.
Posted: Sat Jul 10, 2021 8:37 pm Post subject: |
Those don't look oily enough to give me great concern; for sure we've run with plugs much dirtier and only the very slightest power loss.
So yeah, I'd focus on making sure your fuel system is fully up to snuff. Wouldn't hurt to check spray patterns too... _________________ Vaughan Scott
Posted: Sun Jul 11, 2021 2:46 am Post subject: |
Looks 924 normal to me  _________________ Supercharger and EFI kits
gml
Posted: Tue Jul 13, 2021 5:50 am Post subject: |
That's a huge relief! Thanks both. _________________ George
Posted: Thu Jul 15, 2021 3:07 am Post subject: |
In addition to great advice above, check for vacuum leaks and do a compression test. _________________ White 87 924S "Ghost"
