safe
Posted: Tue Jun 01, 2021 4:58 pm Post subject: Clutch disc thickness |
Hi
I can't find the specifications for new and wear limit for a NA clutch disc. Anyone who has that spec handy? _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe |
Posted: Tue Jun 01, 2021 5:08 pm Post subject: |
Check the specifications document not super clear, but should be an indication
New 10.1-10.4
Wear limit: 8.5mm with asymetrical wear
Lateral run-out,: max 0.6mm with diameter 200 _________________ 1980 924 Turbo
safe
Posted: Tue Jun 01, 2021 5:52 pm Post subject: |
| Cedric wrote: | Check the specifications document not super clear, but should be an indication
New 10.1-10.4
Lateral run-out,: max 0.6mm with diameter 200 |
Thanks, I'm calling 8.8mm good enough!
Lateral run out... probably good, don't want to know!
I got a little worried, this engine had washers (normal washers) underneath the pressure plate spacing it out ~1mm. I was thinking that they had used the wrong disc somehow and tried to compensate for that.
I'll try to lift the engine back in tonight if things turn out as planed. _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
