Its ALIVE again and question(s)
Porscheaddiction
PostPosted: Sat May 06, 2006 11:52 am    Post subject: Its ALIVE again and question(s) Reply with quote
Its official my car is back on the road again after one year. What a feeling to be behind the wheel of a porsche again. . I have learnt alot during the year with the top end rebuild. My idle is bit high right now but Im sure its because the ignition timming is advanced bit too much(timing done the hardway by ear) will correct that one tommorow. Question do to time passed, My temperature gauge is not registering, I have traced it to a wire that was forgotten to be connected, wire colour is blue/yellow and according to factory and haynes manuals this wire connects to the "coolant temperature sender" Where is that sender? is that the coolant temp sensor on the back of the head near the thermo time switch? if not where is it ? and if it is how does this wire connect up? the wire has a female spade type connector on it but I cant seem to locate where it plugs in to. Anyone have pics of this I would be very gratefull.
thanks
Chris.
1981 924 NA (Restoring mode)
1984 928S (Enjoying the driving season)
Tigger937
PostPosted: Sat May 06, 2006 12:00 pm    Post subject: Reply with quote
Yes, that is the sender next to the thermo-time switch on the rear of the cylinder head. There is a flat top on the top of the sender and the spade connector just pushes on the flat top.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
Porscheaddiction
PostPosted: Sat May 06, 2006 12:21 pm    Post subject: Reply with quote
Ok thanks but I think the flat top is gone on mine somehow lost on disassembly 1 year ago, but I will try take another look in the morning.
Im just so happy its all back together its amazing how much you can miss driving a p-car until you dont have access to it, all the money spent and headaches and disappoints I have gone through with this car were all put aside and made worth it tonight when I turnt the key and went out in the car for a 10min drive. Cant help repeating sorry but what better place to rant about achieving this after so much time has passed.
Chris.
Tigger937
PostPosted: Sat May 06, 2006 12:24 pm    Post subject: Reply with quote
I know the feeling, I just fired mine up today too after several weeks of fix this, fix that. Great feeling eh?
1981 931 (Concours)
Porscheaddiction
PostPosted: Sat May 06, 2006 12:31 pm    Post subject: Reply with quote
Great feeling YES was a long time comming...thanks for the pic. I was looking at it in photo shop and enlarged it I dont see where the wire plugs into.
PostPosted: Sat May 06, 2006 12:34 pm    Post subject: Reply with quote
The connector is like the head of a tack which allows the spade to connect from any direction.
Porscheaddiction
PostPosted: Sat May 06, 2006 12:37 pm    Post subject: Reply with quote
so it just gets pushed on to the part that is sticking up in the pic?
I just want to be sure Im doing this right.
Thanks. Chris.
PostPosted: Sat May 06, 2006 12:39 pm    Post subject: Reply with quote
Thats it and a real PITA to get to.
Porscheaddiction
PostPosted: Sat May 06, 2006 12:46 pm    Post subject: Reply with quote
well of course it is a PITA when is anything ever easy on these cars lol I just finished today changing the heater bypass hose that goes to the firewall that was fun. makes me wonder if in Germany if Porsche techs are all very small people to get into these nooks and cranies. )
Tigger937
PostPosted: Sat May 06, 2006 12:53 pm    Post subject: Reply with quote
Unless somebody knows an easier way, I think you'll have to remove the dizzy to reach the temp. sender. Not too bad, only 1 bolt.
1981 931 (Concours)
PostPosted: Sat May 06, 2006 12:56 pm    Post subject: Reply with quote
I just took a picture and emailed it to you...
PostPosted: Sat May 06, 2006 1:03 pm    Post subject: Reply with quote
You were right beside the temp sensor.....the hose in the picture I sent you is the one you probably replaced.
leadfoot
PostPosted: Sat May 06, 2006 1:51 pm    Post subject: Reply with quote
Actually all the German 924 mechanics are reall tall and lanky and have double jointed wrists...
Leadfoot
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
Stampedetrail
PostPosted: Sat May 06, 2006 5:42 pm    Post subject: Reply with quote
Leadfoot
They must be shape-shifters or something with two left hands and 10" fingers. I hooked that one up recently as well, so that I could un-hotwire my fans. That thing is a pain & I dont know what the perfect solution is if you dont have a stock connector, but I suppose you could lasso & solder if necessary. I deformed a standard spade clip & slipped it on & its stayed on so far... Nice pic, tigger937.
1977.5 924 "Martini" head / New Old Stock rebuild
1985.5 944 Why? Because I can.
