kondzi
Posted: Fri Oct 02, 2020 5:20 am Post subject: 931 strange rattling sound from turbo/bov |
If you don't drive the car daily, it breaks right?
Recently started to do some maintenance job on my 931 and this thing came out (watch with sound).
https://youtu.be/JDaZDh9CTc4
I can notice it only when idling. Did not observe anything annoying when driving the car. It shows up for few seconds, and disappears, then again 1-2 seconds rattling. Turbo is dying and resonating? Not an expert with turbochargers here.
Tried to spot where the sound comes from with a steel rod attached to my ear. It's either turbocharger case or BOV (is that correct name for the integrated valve?).
Any hints welcome. _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Posted: Fri Oct 02, 2020 8:04 am Post subject: |
Bov piston rattling inside the turbo. Will likely be one or both nylon washers broken down on the end caps. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
kondzi
Posted: Mon Oct 05, 2020 4:02 am Post subject: |
Many thanks for the hint. Will check that, just need to find some time to remove the turbo from the car. _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Posted: Mon Oct 05, 2020 4:57 am Post subject: |
Try it without removing the whole turbo.. _________________ 80 Turbo - Slightly Modified |
Posted: Mon Oct 05, 2020 6:28 am Post subject: |
| Fasteddie313 wrote: | | Try it without removing the whole turbo.. |
+1 _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
bureau13
Joined: 07 Sep 2017 Posts: 495 Location: South Florida
Posted: Mon Oct 05, 2020 10:38 am Post subject: |
I was able to get both end caps off and replace those seals without removing the turbo. It was a pain in the butt but it can be done. Hardest part is getting the right tool on those bolts...it took several different ones. Also, there wasn't enough clearance to fully remove the piston from the valve, but it didn't really matter. _________________ 1982 931
1986.5 Silver 928S
2008 Volvo XC90 (Daily)
Past lives (I miss them all):
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen) |
kondzi
Posted: Mon Oct 05, 2020 7:40 pm Post subject: |
Ill give it a try, but Im 6,5ft tall and not the thinnest one Sometimes its just impossible to put my hands into some corners. _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Posted: Mon Oct 05, 2020 9:10 pm Post subject: |
I found it easy to remove the cap on the chassis rail side plus the piston and spring. I gave up with the cap on the engine side
Despite having brand new nylon washers on both caps after a full turbo rebuild, I endured the rattle for a few months. It finally went away after removing the piston and spring and stretching the spring a little to tighten it all up to avoid the rattle.
Taking the turbo off will take you at least 4-6hrs off and the same back on. So that's the last resort. Plus you will open up new issues by removing _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
kondzi
Posted: Tue Oct 06, 2020 10:45 pm Post subject: |
Im not afraid of time consuming works, not after I did clutch in my late 951 Just finished wheel bearings all corners and big brakes. BOV needs to wait a bit. Will let you know how it goes with BOV. _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Posted: Wed Oct 07, 2020 12:17 am Post subject: |
I forget if you have had your turbo out before..
How much of a “while your in there” list do you want?
Great time to refresh the HG even  _________________ 80 Turbo - Slightly Modified |
kondzi
Posted: Wed Oct 07, 2020 1:31 am Post subject: |
HG? What that stands for?  _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Posted: Thu Oct 08, 2020 2:37 am Post subject: |
Head gasket _________________ 80 Turbo - Slightly Modified |
