931 spark plug change
emhewitt
PostPosted: Fri Sep 25, 2020 11:28 pm    Post subject: 931 spark plug change Reply with quote
My mechanical expertise is limited to things that easily screw or unbolt easily. In this case, those qualifications are falling short....How can I get a spark plug wrench the hard to reach plugs on my 1981 931?
Thanks
Michael
Michael Hewitt
peterld
PostPosted: Fri Sep 25, 2020 11:35 pm    Post subject: Reply with quote
Do you have the factory toolkit which came with the car? Excellent plug remover in there. Otherwise normal plug socket and several joints (wobblies).
80/81 932/8 ROW
chuck21401
PostPosted: Wed Sep 30, 2020 11:04 am    Post subject: Reply with quote
I removed the charge tube when I changed the plugs in my 931. At little extra work but less frustration with the plugs that are not easy to reach. Of course stick a rag in the lower pressure pipe to prevent anything from falling into the turbo. Also be sure to set the spark plug gap to spec...then tighten the plugs to torque spec.
PostPosted: Thu Oct 01, 2020 12:08 am    Post subject: Reply with quote
The original tool is really great.. It’s not super fancy or anything but works perfectly.. I pull my plugs quite a bit.. Currently BR9ES..
I also always try to blow the spark plug wells out with compressed air before changing the plugs because dirt can get in there and stay..
80 Turbo - Slightly Modified
