snakoil
Joined: 09 Feb 2010 Posts: 362 Location: Montreal, Canada
Posted: Thu Nov 28, 2019 11:12 pm Post subject: Custom throttle cable help |
Hi guys, with my weber conversion I had to change my throttle linkage and cable.
The kit I bought comes with a new cable with a naked pedal end,
Meaning I don't have a cap to make it stick in the black plastic square on the oem cable.
The way the oem thorttle cable ends make me thing the cap end is done once the cable is in the car and the cable in the plastic square.
Doe's anyone know how I can make a similar end to my generic cable so it works?
I assume there might be some cramping tool to do such ends as I don't have any welding tools _________________ 1979 924 NA |
MikeJinCO
Posted: Mon Dec 02, 2019 1:45 am Post subject: |
I have used the stock cable on 2 cars now. They both have center pull setups. I had to fabricate brackets for both and they are different, the first a simple bent one that bolts to the air horn mount, but tends to move around a bit due to the single mounting point. The second is bolted to the bottom of one carb and takes a bit of welding for the race car. If you can work with 16 ga steel a bit and have access to a mig welder I would be able to send some drawings of each. Or, I might have time to make one for you this winter if a special built cable is too expensive. I'll make it home in about 2 weeks and can then send pictures of both. _________________ Mike
'67 MG Midget Dp
snakoil
Posted: Mon Dec 09, 2019 10:27 pm Post subject: |
Well I don't have access to a mig myself but could always drop it off to a local machine shop.
I was hoping I could find a fitting similar to what is used on a bycicle brake lines.
here is a closeup of the end I cut off and my new cable ending.
And you can see the platic part that mounts to the pedal.
Posted: Tue Dec 10, 2019 7:27 am Post subject: |
Use a 944 cable, still available new, and modify the throttle body/carb end with screw on or solder on nipple _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
snakoil
Posted: Sat Dec 14, 2019 12:34 am Post subject: |
| Carrera RSR wrote: | | Use a 944 cable, still available new, and modify the throttle body/carb end with screw on or solder on nipple |
I might order a cable to try it out as i’m ordering from paragon this week anyway but i’m afraid it will be too short.
As you can see in this pic my throttle cable needs to come from the firewall side instead of stock driver Side
