Kenodog
Posted: Sun Oct 06, 2019 10:22 am Post subject: Weld in roll bar install |
Hey homes and homies. Anyone that's had a weld in roll bar can you tell me did you cut holes in the sloping sheet metal in front of the rear wheel arch to access the sub frame or did you weld it directly to the flat bit ? The fellow doing the install says he needs to cut it and pass the bar through to the support underneath but this seems very wrong to me....
Any help is always appreciated
Me _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
TJC
Joined: 04 Apr 2010 Posts: 828 Location: Northwestern-ish Arizona, USA
Posted: Mon Oct 07, 2019 12:46 am Post subject: |
Can't address your application directly without seeing a photo or diagram of your roll bar but the roll cage in 924-005 did not pass through the floor at any point and had reinforcing pads welded to the floor in places where it attached. Is yours a kit from someone or is your fellow making one up?
It also didn't pick up on the wheel housing but was welded to the floor in the rear seat area and then went all the way to the back of the hatch compartment. Check out my web page for photos.
Also the 4 point bolt in, (could be welded as well), roll bar I had in my 924S, (an Autopower if I remember correctly), didn't "pass through" the body. Sorry, no photos of that one. _________________ '95 BMW 318i/5 ..."Pearl"
'04 BMW X3..."Xander"
Still on the Prowl!
www.ttrs1.com |
Posted: Mon Oct 07, 2019 3:06 am Post subject: |
I’m sure many ‘specialists’ will have their own way of doing it. But for EMC Motorsport in the UK whom built many, many 924/944/968 race cars weld spreader plates and mounting boxes to the sill, rear seat slope and wheel arch as per ....
jpg-3 by stevenmcooper, on Flickr
And
jpg-4 by stevenmcooper, on Flickr _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Mon Oct 07, 2019 6:56 am Post subject: |
SCCA rules don't allow cutting holes in the floorpan but welding in the plates like Carrera RSR's pics is the perfect way to install a cage. _________________ 1979 924 NA race car H-Prod SCCA
Posted: Tue Oct 08, 2019 12:09 am Post subject: |
I have the HanksVille hot rods Spec944 cage from Denver and it goes in like Carrera's with addition of 1/8" pad with a lip on the main hoop, which is probably there but I didn't see it in the pic. It took some hammer work on the roof ribs to get it in there, it is a very tight fit. Every connection point to the body has a chassis reinforcing pad. _________________ Mike
macBdog
Posted: Tue Oct 08, 2019 5:19 pm Post subject: |
CAMS (governing motorsport body) rules in Australia say to do it like this:
 _________________ 1979 931 with a 350 chev
1973 911E with EFI
Joined: 29 Jul 2001 Posts: 9069 Location: Royal Oak, MI, USA
Posted: Sun Oct 13, 2019 9:57 pm Post subject: Re: Weld in roll bar install |
| Kenodog wrote: | | ...The fellow doing the install says he needs to cut it and pass the bar through to the support underneath but this seems very wrong to me.... |
Sorry, been on vacation.
The above statement tells me your welder doesn't know 924/944s. That flat section IS the structure.
But he can still do a good job, just needs to learn his subject a bit more.
That flat part is correct for a solid tie-in. At the very least, a flat plate to help spread the load under the end of the tube will help. As shown in the ref Aussie pics (red car).
The REAL way to do these when building a custom car is:
- make the tubes too long when bending
- punch through the frame rail/rocker with a hole saw
- drop the tubes/hoop through the holes you just made in the rockers
- weld the a-pillar bars, halo and main hoop together, with the main structure of the cage dropped down so you can get to the top of the tubes to finish the welds all the way around
- raise the cage back up until its touching the roof
- trim the tubes to length, so you can JUST slip the mounting plate underneath the end of the tube, with the top of the cage still contacting the roof.
- finish welding the plates in place to the rockers, and the cage to the plates.
And that is how you build a cage that can survive a roll without even cracking the windshield!
As for that blue car reference - point and laugh with me at that center bar going to no-where in the middle of the main hoop cross-bar. Tubes need to end in nexus points; any loads imposed on that bar will go no-where. Hopefully your fabricator knows better.
That EMC cage in the blue car actually looks quite shitty to me. Note also the rear main hoop braces going to weak sheetmetal on the arches - no structure there to tie in to. Those tubes should go to the sides of the rear load floor; if you're familiar with the underside of the 924/944, you can see the frame rails you end up tying in to. Ideal IMO is to grab the very front edge/corner of the floor, since that's where the shocks mount, and if you're wanting to use coilovers, that'll help the load paths.
That said, the OG Racing cage in our 924 - which has survived too many visits to walls and frame racks - was tied in to the floor about halfway back, and seems to work decently.
I will say that the EMC cage does mount to the correct frame rail points on the boxes for the a-pillar bars and main hoop, so glad to see they got that right. I've seen far too many cages that blow right past these and go to the floor, which of course by contrast is pretty flimsy. Google "cage punch-through" if you want to see some scary pics. _________________ Vaughan Scott
Posted: Mon Oct 14, 2019 2:50 am Post subject: |
FYI. That EMC cage in the blue car is made by Safety Devices and is fully FIA approved. Supplied in pieces and welded in by EMC which are the go to 924/944/968 race preparers in the UK. It’s the same cage cage in my car but bolt in rather than welded in. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Mon Oct 14, 2019 4:05 am Post subject: |
It looks fairly good, but that tube attaching in the middle of the cross tube is such a basic mistake it sound weird that its a safety devices design. _________________ 1980 924 Turbo
Posted: Mon Oct 14, 2019 6:10 am Post subject: |
| Cédric wrote: | | It looks fairly good, but that tube attaching in the middle of the cross tube is such a basic mistake it sound weird that its a safety devices design. |
Not sure that is a stock Safety Devices cross tube? Rest of the cage is. Other cars they have prepped have it, some don’t, so there must have been a reason?
https://www.porscheclubgb.com/forum/download.axd?file=0;511915&filename=rearcageshot.jpg
https://racecarsdirect.com/Advert/Details/85525/1993-porsche-968-race-car _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Mon Oct 14, 2019 9:43 pm Post subject: |
Well, once it's in, there's any number of ways a cage can be ruined...
And those rear braces are still relatively useless IMO. _________________ Vaughan Scott
TJC
Posted: Tue Oct 15, 2019 1:55 am Post subject: |
| 924RACR wrote: | Well, once it's in, there's any number of ways a cage can be ruined...
And those rear braces are still relatively useless IMO. |
I was looking at that as well. It appears that some type of box/pedestal is welded to the inner wheel well and then the bars are welded to it. Seems to be just another piece to collapse before the wheel well does, but perhaps it's just the way I'm seeing it in the photo.
The bolt-in roll bar in my 924S that I referenced above had the rear braces attaching at the wheel well location too but to be honest it wasn't a real serious safety device. Sort of a "better than nothing, something to modify to attach shoulder straps to, boy racer" piece of work. Hell, it came with the car when I got it!!!
I do like the blue though! _________________ '95 BMW 318i/5 ..."Pearl"
Still on the Prowl!
www.ttrs1.com |
